High idle, need help
Discussion in '1st Gen. Tacomas (1995-2004)' started by King5065, Aug 30, 2024.
  1. Aug 30, 2024 at 8:33 AM
    King5065
    King5065 [OP] Member
    Eli
    2001 White Tacoma SRS
    To anyone that can help me, my 2001 Tacoma is idling high and I'm not sure why. There is no check engine light on. Any help would be greatly appreciated.
    HondaGM likes this.
  2. Aug 30, 2024 at 8:37 AM
    02hilux
    Planet: EARTH
    IACV
    HondaGM, MadNachos and Lockdahubs like this.
  3. Aug 30, 2024 at 1:32 PM
    FixMyTaco
    FixMyTaco Well-Known Member
    Lee
    Alaska
    96 ext cab 4wd mt 3rz 400k mi.
    Rebuilding seats with leather from furniture and extra padding. Might put leather on the dash and other interior parts.
    Look for vacuum leaks. Clean the MAF sensor. Clean the IAC. Check coolant temp sensor.
    HondaGM and MadNachos like this.
  4. Aug 30, 2024 at 1:59 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    How high?
    HondaGM likes this.
  5. Aug 31, 2024 at 7:43 AM
    King5065
    Eli
    Starts at 1k and as it warms up it gets between 1800 and 2k
  6. Sep 4, 2024 at 2:53 PM
    AW11
    AW11 Well-Known Member
    Frank
    2002 Dbl Cab 4x4 3.4l
    IACV issue or low coolant?
  7. Sep 4, 2024 at 11:11 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Has any maintenance work been performed recently?
  8. Sep 5, 2024 at 1:00 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Start replacing all those cracked and dry rotted vacuum hoses.
