High idle problem.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fabulous, Sep 15, 2010.
  1. Sep 15, 2010 at 10:11 AM
    Fabulous
    Fabulous [OP] Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
  2. Sep 15, 2010 at 10:16 AM
    DocBrown86
    DocBrown86 Yota Doc
    Brian
    San Diego (Spring Valley)
    04 Prerunner
    toytec coil spacers, tokicko struts/dubcab springs, energy suspension rack bushings, bilstien hd shocks, K&N FIPK2, Flowmaster 50DF, ScanGuage2, 5000k HID's, horn mod, other stuff that I forgot to list
    Since you had your battery disconnected, I'd say your ECU needs to re-learn your driving habits.
    EDIT: didnt notice you said 6 days ago.
    Its normal for standard trans Toyotas to hold RPM when clutch in. It extends cat converter life. Should have nothing to do with your lift/alignment.
    EDIT: RE-RE-read your other post :rofl:
    You just started driving it after you had the battery disconnected. Your ECU needs to re-learn everything (shift points/throttle pos/etc.) Take it for a 20 min drive, everything should be back to normal.
  3. Sep 15, 2010 at 10:43 AM
    Fabulous
    Fabian
    Calgary, AB
    Cool. It'll have to wait until after the alignment as it is way off. I wondered if it was that as well as the drive I did yesterday was a short trip to the car wash, then to the grocery store, then home...maybe 4 km's total, but I caught every frigging red light! It never did it before when I disconnected the battery, but then again I was in my small hometown in BC, and there is only one red light. Hopefully that is what it is. Thanks for the help.
  4. Sep 15, 2010 at 10:45 AM
    DocBrown86
    DocBrown86 Yota Doc
    Brian
    04 Prerunner
    No problem :D
