high idle rpms till truck warms up
Discussion in '1st Gen. Tacomas (1995-2004)' started by little bear, Feb 10, 2015.
  1. Feb 10, 2015 at 11:58 AM
    little bear
    little bear [OP] Well-Known Member
    Barry Hobson
    Canadian, Texas
    silver streak 2017 Tacoma trd sport 4dsb 6sp MT
    Black badges, TRD pro grill, clazzio seat covers, falken wild peaks AT3W 265 70R17, Fuel Trophy wheels, taco tunes 10" sub and Jl Audio all around speaker upgrades, dynamat doors and interior, Meso's interior lights, gasshole, waterproof led bed lights, headstrong progressive leaf pack, bilstein 5100's with OME 887 coils, ecgs bushing, nfab nerf bars, cbi t3 aluminum bumper
    What could be causing this....I have a 2000 3.4l 4x4 with 5 speed tranny that runs about 1500rpms after starting and will idle there till the truck warms after driving for several minutes. After it warms it sits around 1000rpms. I know often times after I drive awhile and then run in an out somewhere and try and start it back up if I don't let the starter cycle enough then the engine is tough to start for a little while. Maybe I am running too rich but have no idea if that is even stuff you can adjust.... the truck runs well I just guess it has me confused yet again
  2. Feb 10, 2015 at 12:06 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    when cold there is a solenoid that holds the throttle body open to fast idle so the truck can warm up and not stall.
    the engine coolant runs through a vacuum switch that turns it off when the truck warms up.
    it may need adjusting but it should be idling around 1200 when cold so see what the manual says your engine should run at when cold
  3. Feb 10, 2015 at 1:34 PM
    little bear
    Barry Hobson
    Canadian, Texas
    Which part would need the adjusting?
  4. Feb 12, 2015 at 3:00 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    located your IAC, idle air controller, and try cleaning out all the gunk.
  5. Feb 12, 2015 at 4:07 PM
    DestroyerLite
    DestroyerLite Well-Known Member
    DFW
    04 Tacoma SR5 V6 4X4 Auto
    Mine has done that since new... It's a V6 Auto and when I start it up in the morning (and lately it been a bit chilly in TX) it will idle at just over 1500 rpm until about 110-120 degrees according to the UltraGauge. Then it will slowly step down until finally the idle sits at about 600 or 700 when in Drive.
    --Dan
  6. Feb 12, 2015 at 5:49 PM
    keakar
    karl
    louisiana
    well there you go, seams like its working as it should then
    I know my 4 banger idles at 1200 rpm when cold and 650 after its fully warmed up.
