High idle until stopped
Discussion in '1st Gen. Tacomas (1995-2004)' started by BV227, Sep 22, 2014.
  1. Sep 22, 2014 at 9:53 AM
    BV227
    BV227 [OP] Member
    02 Tacoma
    02 Tacoma. At first start-up I get high (1800-200) rpm for about 15-20 minutes of driving, a little less in summer, but well past warm-up. If I push in clutch and coast up to a stop, engine will run at 2000 rpm until I come to a complete stop. When the wheels stop turning, idle comes down to normal (750). High idle in neutral resumes when I go to the next stop. This goes on for 15 to 20 minutes of driving, then quits. Any ideas???
  2. Sep 22, 2014 at 3:19 PM
    jspansel
    jspansel Just duct tape it
    Jay
    Central OR
    01 V6 Xtra Cab Tacoma, 5 Speed, 4x4, Lifted
    5100s front at 2.5" with Moog replacement springs, 5100s in rear with 2" Wheeler's AAL
    Mine is doing pretty much the same thing... cant figure out why. Sometimes it does not stop the whole drive, sometimes it does not do it at all.
  3. Sep 22, 2014 at 3:20 PM
    jspansel
    Jay
    Central OR
  4. Oct 4, 2014 at 4:03 PM
    BV227
    BV227 [OP] Member
    02 Tacoma
    Well, rats! This 1st gen group has helped me with headlights, seatbelt retractors, squeaky clutch pedal, etc., but no one can help with this high idle problem? Don't feel bad; I've tried half a dozen shops and two dealers and no one else can figure it out either. Dealer shops always come up with "cannot duplicate problem in shop" a real copout, which translates to "we don't know and we don't care."
    Thanks for giving it a try.
  5. Oct 4, 2014 at 6:41 PM
    Combatman
    Combatman Well-Known Member
    Sioux Falls sd
    1996 Tacoma 4x4 3.4 Manual
    31" Wrangler tires
    I had the same issue on a 2005 mustang I used to have, never could figure out what was wrong with it. It Aways concerned me, so I've been watching this thread hoping for an answer. Good luck man!
  6. Oct 4, 2014 at 6:54 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I'd try a new coolant temp sensor and replace any cracked or brittle vacuum hoses. Make sure the EGR valve is functioning properly and isn't stuck open or closed.
  7. Oct 4, 2014 at 9:30 PM
    kigmob
    kigmob Well-Known Member
    James
    New Orleans
    97 TRD S/C 4x4 V6 5spd
    ICON/TC TRD Supercharger URD 2.2 and 7th
    Clean the IAC valve. Its located on the bottom of the throttle body. It controls your idle.
  8. Oct 4, 2014 at 9:42 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    I have this same idle issue and I have cleaned the IAC valve. Here is my thought on that. Obviously it is working as it is opening too much causing a high idle. Also when at a complete stop it idles down perfect. Also when I don't have the issue it idles perfect. I have thought about the coolant temperature sensor as well. If that sensor is faulty, the computer could be in warm up mode instead of switching like it should. Just my thoughts.
  9. Oct 5, 2014 at 4:56 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Cam sensor, too.
  10. Oct 5, 2014 at 5:14 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Hi there, i have the same issue. Have had it since i got the tx.
    Have had at several dealerships. No real answer from any of them. I had an 05 4 cyl. That did not do this. I also noticed i do not have a cold start pump either. Not sure if any of you do complaining.
    The most recent trip to dealer said that it is for smog purposes to burn off extra stuff in the chambers.....lol its fuel injected not carbureted I don't buy it I told him and they told me that they give me the number for the engineer so I could talk to him so he could blow some more smoke.....I definitely will be watching this to see if anything comes up
  11. Oct 6, 2014 at 12:40 PM
    VintageFast
    VintageFast Well-Known Member
    Jim
    DFW, Texas
    02 Prerunner 3.4
    i've got the same problem. Doesn't do it all the time though and it seems to quit after warm up.
  12. Oct 7, 2014 at 1:08 AM
    lunch box
    lunch box diesel mechanic
    2000 trd tacoma
    diff lock grey wire mod k&n77series cold air intake 2nd gen s/c water meth injection 7th injector urd 5100s lift all the way around add a leaf new excedy clutch and rear main seal scan guage 2 wet okole covers.bazooka tube.& some minor body stuff.TRD supercharger,URD 7th injector kit
    mine did that after a trip to the coast and back I unhooked my batt ground for a few minutes and re connected it,,,trying to reset the fuel maps and it worked ..havent had the problem since....
  13. Oct 7, 2014 at 2:17 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    IAC valve acting up, or a vacuum leak is the first thing that comes to mind.
  14. Oct 7, 2014 at 11:13 PM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    It works tell computer kickss back in.
  15. Oct 7, 2014 at 11:20 PM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    brought it to several dealerships you would think they would have found sonething like that?, and I think earlier in the post somebody said they cleaned thier lac valve to no luck already?
  16. Oct 8, 2014 at 7:47 AM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
  17. Oct 8, 2014 at 1:57 PM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    It's your idle air control valve. It reads that you're traveling at a faster rate of speed than zero and it'll adjust the idle accordingly. When it starts wearing out or is dirty it acts up and doesn't operate correctly.
  18. Oct 8, 2014 at 3:10 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I would say a vacuum leak given the age of his vehicle, either he has a vacuum leak somewhere, or his MAF is dirty if the IAC has been addressed.
  19. Oct 8, 2014 at 4:54 PM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    I have had the issue since i bought the tx. And 2 posts i think above a guy with a brand new pro edition, hopefully you know what that is. Some do not. Has the same issue.
  20. Oct 8, 2014 at 4:57 PM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    I'm thinking temp sensor
