High Idle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by themuffinman619, Feb 29, 2012.
  1. Mar 13, 2012 at 3:18 AM
    oneshot808
    oneshot808 Well-Known Member
    Oahu, Hawaii
    16 T4R 4x4 GH05T
    Wet Okoles/Weather tech all around, LED's +HIDS, 6"Fabtech w/ Fox front & rear
    Same issue I had when I did my spark plugs/throttle it usually goes back to normal. Mine went away after two days.
  2. Mar 13, 2012 at 5:10 AM
    nofx230
    nofx230 Member
    Matthew
    Colorado Springs,CO
    2000 TACO
    Yeah I understand they are diff systems and that your trucks use fly by wire but figured I'd try the 2nd gen guys as most of you have owned a 1st gen plus the 1st gen guys recommended hit my linkage with a rubber hammer real hard. Not really an answer I was looking for!
    Vacuum leak wouldn't explain the bouncing idle durning coasting??? Plus the bouncing only stops when I slow down to past 5mph or slower ie dead stop but still sits at 1100-1200.
    Something's up guess I'll start double checking everything again. Thanks
  3. Mar 21, 2012 at 5:50 PM
    ADVBedouin
    ADVBedouin Well-Known Member
    Central CA Coast
    '10 Preunner Acc Cab 2.7L 5spd
    2" CCM front spacers, secondary airfilter gone, OEM 16" alloys, Trailer hitch gone, Seat belt buzzer gone, Ignition key buzzer gone, shortened fact. antenna.
    I'm now having the same issue too: My girlfriend's '04 Taco, V6, Auto, 4x4, it's now idling @ 1200-1400 rpm's, but it's not surging. Her airfilter was really dirty, plugs were really worn & looked at least 40k old, throttle body was very dirty too. I asked her if she'd run the baja1000 or something.. :/
    I changed the plugs, new airfilter, & wiped out the throttle body really well as it had some buildup too. I only removed the intake snorkel to get to the plugs & left the throttle body in place. I'll assume the ECU's 'relearning' things now & will idle back down soon, but reading these posts it sounds like it may take a while..
    If it doesn't idle back down by this weekend I'll disconnect the battery & see if that solves it. I'll let y'all know what I find out.
  4. Mar 21, 2012 at 6:00 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    My Tundra relearned within 5-10 "commutes" when I cleaned the TB.
  5. Mar 22, 2012 at 12:53 PM
    ADVBedouin
    Central CA Coast
    Yep, GF says the idle is now back down to normal after driving it for a couple days, so all is well.
  6. Mar 22, 2012 at 4:23 PM
    themuffinman619
    themuffinman619 [OP] Play stupid games, win stupid prizes
    themuffinman
    Your moms house
    :thumbsup:
  7. Jun 5, 2012 at 3:40 AM
    Rebel78
    Rebel78 Member
    I have the same problem, the RPM bounces between 1000-1400 when I coast (5AT) and it goes down to 750 rpms at lower speeds. The vehicle used to settle at 750-800 rpms when i coast from any speed. Could this issue be solved by changing the throttle body?
  8. Jun 5, 2012 at 5:27 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Has anyone checked the MAF Sensor. They are easy to damage and "could cause " this type of problem.
  9. Jul 4, 2022 at 6:51 AM
    ironworker1
    ironworker1 Member
    2004 Tacoma 4x4 TRD
    Truck was idling correctly prior to below actions...
    I disconnected from my battery to clean the terminals. Upon reconnection the engine was surging to determine idle. Seems like the ECR is trying to determine where it needs to be idling.
    I now know never to disconnect my batter unless necessary.
  10. Jul 4, 2022 at 8:06 AM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Did you get the vacuum line back on the back side of the intake?
