High idle
Discussion in '4 Cylinder' started by Draveling, Oct 4, 2012.
  1. Oct 4, 2012 at 8:05 PM
    Draveling
    Draveling [OP] New Member
    Dan
    Willow Alaska
    I just put a new head on my 2.7 Its starts and runs strong but its idling around 2000rpm It trys to drop back to normal idle sometimes which lead me to belive it was the TPS but I put a new one on and no change. I traced all the vacumme lines and everything looks good I even sprayed starting fluid all around while it was running to see if I got a change and nothing. Im not getting a check engine light.
    I was just wondering if anyone has any ideas. I dont want to have to put it on the dio.
  2. Oct 11, 2012 at 5:56 PM
    LDurchy
    LDurchy Well-Known Member
    Cedar Falls, Iowa
    Wonder if that new head was a milled head. Higher compression ratio might idle faster, also would 'run strong'.
  3. Oct 13, 2012 at 6:31 AM
    BamaToy1997
    Bill
    Navarre, FL
    The amount of higher compression from a simple milled head would not cause a higher idle. I have a milled head that I installed on my engine and I never had an idle issue.
    Check the basic mechanical parts first Dan. Did you accidentally adjust the throttle cable too tight? Is the cable or pedal binding/stuck? Look at the linkage for issues. Is the CEL on? Possible codes could be the culprit. Not all codes will turn on a CEL, so scan for codes just to be sure.
    OP, you mentioned that you have a 2.7 but more information would help. What year? Auto or manual? 2 or 4wd? The more information you provide the better off we can help.
  4. Oct 13, 2012 at 6:36 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Sounds like a vacuum leak.
