High Idle
Discussion in '1st Gen. Tacomas (1995-2004)' started by crzylee, Jul 20, 2009.
  1. Jul 20, 2009 at 1:56 PM
    crzylee
    crzylee [OP] Member
    Brandon, Ms
    99 tacoma xcab 4wd 3.4L
    Hey guys, names Lee and I just purchased a '99 taco xcab 4wd for $1200. The one problem on this truck that bothers me the most is the high idle.. parked at a stop sign I idle near 3000 RPM. The truck had an extra TPS in the cab when I bought it and put it on thinking this would solve the problem, but didn't. I know the spring on the throttle linkage where the throttle cable is connected to the throttle body (the outside spring not the inside one) is very loose and probably needs replacing.
    Can anyone help me diagnose my problem? and also where is the best place to get engine parts like this spring or TPS?
    Thanks guys!
  2. Jul 20, 2009 at 2:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Welcome to TW! Get the throtle spring replaced, and see if that clears it up.
  3. Jul 20, 2009 at 2:10 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    Holy crap only 1200, that's incredible.
    I unfortunatly can't offer any advice but 3000 rpm is alot more than a high idle. you could coast at 70 and not even touch the gas. jk i know it would go down pushing the truck.
  4. Jul 21, 2009 at 5:55 AM
    crzylee
    crzylee [OP] Member
    Brandon, Ms
    Yea I caught a steal on the truck no doubt. Its not in mint condition by any means but it has potential. Something I noticed this morning driving to work the engine started surging going from 3k to <1k RPM. It only did this when I was not on the throttle, and then the airbag light came on. Is this a symptom of computer problems?
  5. Jul 21, 2009 at 9:07 AM
    crzylee
    crzylee [OP] Member
    Brandon, Ms
    Got to browsing the forums a little, and got to wondering: the truck has 240k miles on it, the next oil change was due at 219k and never got done, so the maintenance on this truck was shoddy at best. I have replaced the alternator and all 3 belts, but what about timing belt? I know I should replace this, being it probably has never been replaced, is this complicated? I have replaced it on my jeep before but never in another vehicle I have owned. Not saying it is causing my problems but preventative maintenance.
  6. Jul 21, 2009 at 12:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The timing belt should be replaced every 90k miles.
  7. Jul 21, 2009 at 1:31 PM
    crzylee
    crzylee [OP] Member
    Brandon, Ms
    Yea, that what I was reading.. Looks like I know where the Yota will be parked the next few days!!!
    Where is the best parts website to get "dealer only" parts. Called Napa for that spring, and they only showed a gasket for the throttle body in their computer. Everyone tells me these are dealer parts.
  8. Jul 21, 2009 at 8:26 PM
    XBrown
    XBrown Spartacus!
    Xavier
    Phoenix, AZ
    04 Tacoma SR5
    If it's surging like crazy, start looking for a vacuum leak. The idle air control motor can usually only control the idle up to about 2000-2400 rpm.
