High idle
Discussion in '1st Gen. Tacomas (1995-2004)' started by Guam_98taco, Jun 4, 2019.
  1. Jun 4, 2019 at 7:07 AM
    Guam_98taco
    Guam_98taco [OP] Member
    Philip
    98 Tacoma 4x4
    3 inch block up front, add a leaf in rear
    Just got a taco with leaking Valve cover gasket and spark plug seals. Replaced them but now I have a high idle. Currently looking for leaks. Hoses all hooked right. Steady at 1.3-1.5 rpms. What can cause high idle?
    Crodell6 likes this.
  2. Jun 4, 2019 at 9:36 PM
    DPTacomaGuy
    DPTacomaGuy Well-Known Member
    David
    2001 Tacoma 4x4
    Maybe it was idling low before with the vacuum leak and PO adjusted idle to compensate? Now that vacuum leak is corrected the idle is high. Reintroduce the vacuum leak and all should be normal.
  3. Jun 5, 2019 at 12:47 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Are you getting the PO505 code??
    It is normal for the engine to have a high idle till the temperature comes up
  4. Jun 5, 2019 at 2:49 AM
    Jctam
    Jctam New Member
    my 98 has the opposite problem
  5. Jun 5, 2019 at 7:13 AM
    Guam_98taco
    Philip
    98 Tacoma 4x4
    IDK was running perfectly normal before repairs. I'm thinking valve cover isn't sitting all the way down on backside but I haven't confirmed. Could this cause high idle or vacuum leak to cause it?
  6. Jun 5, 2019 at 9:28 AM
    DPTacomaGuy
    David
    2001 Tacoma 4x4
    Any vacuum leak can cause the engine to run at higher rpms to keep running. Surprised there are no codes. If valve cover is not sitting correctly that would be the first place I’d check. Possible that your gasket is not sitting properly.
    OneWheelPeel and J.A.92 like this.
  7. Jun 5, 2019 at 10:42 AM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
  8. Jun 5, 2019 at 3:11 PM
    TWJLee
    TWJLee Well-Known Member
    Jay
    Midwest
    2001 Tacoma 4X4 2.7 5spd access cab 2020 Tundra DC LmTD 2020 F150 5.0
    2020 Tundra GFC 33’s Borla Pro XS FOX 2.0 2020 F150 33’s Magnaflow FOX 2.0 2001 Tacoma 4x4 2.7 5spd access cab new frame 217k 2” lifted Always for sale.
    Hopefully you torqued all to spec, and put in new gaskets on such a job.
    Then made sure all vac lines are in the right place.
    If you cleaned the throttle body, go back and do it again, this time clean the IAC thoroughly also.
    Your idle will go back to where it is supposed to be.
  9. Jun 5, 2019 at 3:14 PM
    Guam_98taco
    Philip
    98 Tacoma 4x4
    Thanks boys. Update u after..
  10. Jun 6, 2019 at 12:26 PM
    sramirez1516
    sramirez1516 Saul R.
    Saul
    2002 Toyota tacoma xtracab prerunner 2.7
    None
    Idle control valve if you don't find obvious leaks. 7 out of 10 that's the problem with high idle. Does ithe idle get lower after it warms up?
  11. Jun 6, 2019 at 12:39 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    If the valve cover isn't down you'll see a pool of oil soon enough.
