High idling after cold start
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoCo, Oct 4, 2008.
  1. Oct 4, 2008 at 7:29 AM
    TacoCo
    TacoCo [OP] Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    So, it's starting to get pretty cold here at night. Started my truck up this morning, and it was idling at around 1500-1600 RPMs in my driveway. Took it for a drive, and once it warmed up, it was idling around 900-1000 RPM's. Does this seem like the norm for most of you, or should I have the dealer look at it when I go in for my complimentary oil change?
  2. Oct 4, 2008 at 9:37 AM
    TheOne
    TheOne Beach Prerunner
    East Coast, nc
    06 Prerunner Impulse red
    stock
    pretty normal while choke is on
  3. Oct 4, 2008 at 9:53 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    normal for the tacoma.....heats up the engine faster.
  4. Oct 4, 2008 at 12:07 PM
    BulletToothTony
    BulletToothTony Im only a dick 90% of the time
    You can call me Susan if it makes you happy.
    Yeah its normal mine has done that since day one when i got it.
  5. Oct 4, 2008 at 10:26 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    all my cars have done it. The higher revs let it warm up faster.
    A Warm engine is a happy engine :D
  6. Oct 5, 2008 at 7:49 AM
    Simon's Mom
    Judy or Jude :)
    SBurl Vermont
    13 TRD OR DC MGM
    Stock for now
    normal wait til you hear at zero & your seat's like a brick :D
  7. Oct 5, 2008 at 8:58 AM
    aaronk
    aaronk Well-Known Member
    2009 Dbl Cab V6 TRD
    As others have said, normal, but my Tacoma seems to warm up at a higher rev than my other cars have in the morning.
  8. Oct 7, 2008 at 7:10 PM
    allrsdup
    allrsdup Well-Known Member
    Sahuarita AZ.
    2017 dcsb trd offroad blazing blue pearl
    u must be young, when i started driving my car had carburetor. when it was cold the choke would be closed and it would idle high. now with newer cars with fuel injection it is all comp controlled but it is the same concept. in other words it is normal all cars do it. till it warms up.
  9. Oct 7, 2008 at 7:18 PM
    hate2work
    hate2work Well-Known Member
    Washington State
    06 standard cab
    Yep, pretty much normal. I start my truck, count to two and then put it in gear and go. Most modern cars are designed to be driven cold, and warm up on the fly ;)
  10. Oct 9, 2008 at 6:34 PM
    allrsdup
    Sahuarita AZ.
    warm up on the fly? count to 2? i hope u don't do that in the winter? i hope i never buy a used car that u owned lol
  11. Oct 9, 2008 at 6:53 PM
    RoyB
    RoyB Well-Known Member
    Chicago burbs
    '09 TRD DC Sport
    my 4 runner heats up so fast. I start it, let it idle a couple seconds, and idle down the street then trying to keep rpms below 2K until I see the needle move, which is usually a couple blocks later.
  12. Oct 9, 2008 at 8:34 PM
    hate2work
    Washington State
    06 standard cab
    Yep, that's exactly how I do it. I hope you're not trying to insinuate that letting your car/truck warm up for longer than that has a benefit, are you? All you'd be doing is wasting fossil fuel.
    BTW, my last vehicle had just under 200k until it got wrecked, ran perfect until the crash. You'd do well to buy one of my used cars.
    There are, of course, exceptions to every rule. For example, if you live in International Falls, Minn, and you park outside in the winter, I'm thinking a different set of rules would apply. :D
    Capiche? :rolleyes:
  13. Oct 9, 2008 at 9:15 PM
    06BLUEDBLSPORT
    06BLUEDBLSPORT Well-Known Member
    Colin
    Lubbock Texas
    12 Tundra DC SR5 4x4 5.7L
    True Dual Flowmaster 40 Series exhaust, Volant CAI, HIDs, Raptor series Side Steps, Weathertech Floorliners, OME 613 Shocks and Coils with Diff Drop, Rear Bilstein 5100 Shocks, ToyTec AAL, Fearless Fabrication Front Bumper
    my brothers who have toyotas start up thier cars and immediatly shift gears, i freak out cause its not right, so when they start and the engine is high reving and they shift and the engine drops rpm's it doesnt seem right, i try to give my truck time to get its juices flowing before shift and my truck is always sitting out side sadly
