high lift jack drops when lowering
Discussion in '2nd Gen. Tacomas (2005-2015)' started by callahansd, Jun 2, 2010.
  1. Jun 2, 2010 at 8:49 AM
    callahansd
    callahansd [OP] Guest
    ok Iv looked at this thing for awhile now and Id rather just have one of you guys tell me what Im doing wrong, whenever i switch the jack to start climbing down, i crank the handle one time and it drops to the ground, I tried not cranking as much (as in not till its straight up), and the same thing happened... any ideas??
  2. Jun 2, 2010 at 9:05 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Or you doing this while it is holding something up?
    It will do that if there is no load on it.
    However if it is doing that while holding a load you have a problem I don't have the remedy for.
    Recap. With a load on the jack you will have to jack it down, until the load is released at which time the jack will slide all the way to the bottom quickly.
  3. Jun 2, 2010 at 9:06 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Put a load on it and it'll hold. If you have it set to lower and there's no load, it'll drop to the bottom.
    Likewise, if you have it set to raise up with no load you can lift the jack part and it'll slide up until it hits something and will hold there.
    As designed.
  4. Jun 2, 2010 at 9:07 AM
    mjp2
    NJ
    Gah. I was beat to the punch. :p
  5. Jun 2, 2010 at 9:08 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
  6. Jun 2, 2010 at 9:24 AM
    callahansd
    thanks guys! i wanted to figure it out before putting a load on it, thanks again
