HIGH, LOW, and FOG beams at the Same Time!!
Discussion in 'Wheeler's Off-Road' started by YotaDan, Jan 4, 2011.
  1. Jan 4, 2011 at 11:48 AM
    YotaDan
    YotaDan [OP] Dan
    Dan
    Oregon
    Activates your low beam headlamps with your high beams for a huge increase in high beam lighting performance!!
    Brite Box Kit for 05+ Tacoma without factory fog/driving lights:
    94.99
    Brite Box Kit for 05+ Tacoma with factory fog/driving lights:
    124.99
    [​IMG] (This kit can activate your factory fog/driving lamps with the high beams!)
    Brite Box Kit for 05+ Tacoma with aftermarket fog/driving lights:
    119.99
    [​IMG] (This kit can activate your aftermarket fog/driving lamps with the high beams!)
    The BRITE BOX™ is a self contained device that greatly contributes to driving
    safety on dark roads by improving both the output and coverage of your vehicle headlights.
    All vehicle headlights have two distinct beam patterns: low beam for close range illumination, and high beam for long range illumination. In most vehicles, when the high beams are activated, the low beams shut off. The resulting choice of "near" vs. "far" illumination compromises safety and comfort because at a maximum, only 54% of the vehicle's lighting potential is being used at any given time. Installing brighter headlight bulbs does little to help because the coverage of the headlights is still compromised. Additionally, if your vehicle has factory installed fog lights, they too shut off when high beams are engaged. How does one solve this problem?
    Enter the BRITE BOX™. Brite Box illuminates the low beams (and fog lights/driving lights/offroad lights with Fog Light Control models) when the high beams are activated which allows 100% of the lighting potential of the vehicle to be utilized. Brite Box provides an even carpet of light that stretches from near to far. Safety and comfort are improved because the driver can now see a larger portion of the road. The safety benefits and circuitry of Brite Box has been proven in millions of miles of over the road testing, and is used by law enforcement and transportation companies.
    Brite Box features easy plug in installation (in most vehicles) and can usually be installed in 30 minutes or less. There are Brite Box models available to fit most domestic cars, light trucks, and sport utility vehicles (SUV's) manufactured from 1976 - 2008.
    MADE IN THE USA!!
  2. Jan 4, 2011 at 11:56 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    excess heat?
  3. Jan 4, 2011 at 11:56 AM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX or College Station, TX
    08 Prerunner V6 Black
    Viper Alarm, In Pro Car Wear L.E.D. Tail Lights, Fog Lights, ScanGuageII, AvidOffroad Light Bar, Ammo Box Mod, Tailgate Theft Prevention Mod, Satoshi Grill, Hella 500ff behind the grill, blendmount, Cruise Control Mod, Fog Light Mod, 5100's @1.75, Toytec TSB AAL 1.5".
    This seems like a nice product for someone afraid of touching there vehicle, but you can do this with about $1 in wire splicers, and wire.
  4. Jan 4, 2011 at 12:03 PM
    TurfTaco
    TurfTaco Is there a long john silvers on the island?
    URE
    07 Deer Collector
    285/75-16 BFG KM1's, AVS vent visors, AVS hood shield, pioneer avic F900BT, pac steering wheel control adapter, Boyo rearview camera, pac ipod interface, tinted windows, Toytec 1.5 AAL, Bistein 5100s (front set to .85) Eibach coils, Black headlights, grillcraft black billet insert, N-fab light bar, 4 Hella FF700 lights & color matched grille, Sockmonkey bedside decals. 16x8 MT sidebiters, Weathertechs, Fabtech spare carrier.
    ^yup
  5. Jan 4, 2011 at 12:11 PM
    YotaDan
    YotaDan [OP] Dan
    Dan
    Oregon
  6. Jan 4, 2011 at 12:15 PM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    About 10 years ago I had the "Brite box" on my 98 Dodge Ram and it did a really good job. It turns both elements of a dual element headlight bulb on when turned to high. Wouldn't do me any good on my Tacoma, since I went with Bi-Xenon retrofits and did the foglight on with parklamps mod, however.
  7. Jan 4, 2011 at 1:45 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Only issue with this on the Tacoma, is that both high/low filaments share a bulb capsule. Running both at the same time will heat it up pretty hot, and could cause them to burn out quicker. This works well on vehicles that have independant high/low bulbs or housings.
  8. Jan 4, 2011 at 1:55 PM
    Bama_TACO
    Winfield, AL
    98 Dodge Ram had dual filament bulbs too.
  9. Jan 4, 2011 at 2:13 PM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    wouldnt this burn out your bulbs super fast?
  10. Jan 5, 2011 at 3:00 PM
    YotaDan
    YotaDan [OP] Dan
    Dan
    Oregon
    Hey Everyone,
    I was able to swing a 10% OFF deal on all Bright Box Products for January!
  11. Jan 5, 2011 at 3:11 PM
    0wrx2
    0wrx2 Well-Known Member
    north nj / upstate ny
    '10 trd sport 4x4. dbl cab. shrt bed.
    for real? doing that would kill the bulbs super fast. thats the reason they switched like they are.
  12. Jan 5, 2011 at 4:16 PM
    YotaDan
    YotaDan [OP] Dan
    Dan
    Oregon
    The bulbs are built for Flash to Pass. Sylvania says that the bulbs are over-built for that reason. These systems have been in use since 1996, and they have never had any bulb issues. We have had great success running these boxes.
  13. Jan 8, 2012 at 2:45 PM
    tbone11212
    tbone11212 Well-Known Member
    fayetteville NC
    07 Tacoma TRD 4x4
    Black Spyder Headlights Black LED Spyder Tail Lights Spyder Smoke Fog Lights HID Headlights and Fog Lights Black LED IPCW Third Brake Light De-badged plasti-dip power window panels plasti-dip center console modded A/C controls JVC 7inch double Din touch screen HD radio Extreme bull-bar color-matched billet grille Billet lower grille color-matched rear bumper 5% tinted windows LED fog lights added HID bulbs added for fog lights Fog light Mod high beam/ low beam mod LED bedlights LED under hood lights aux fuse box Image Dynamics front and rear speakers Blue accent lighting
    I have after market spyder headlights on my 07 taco trd where it has projector headligh and seperate high beam. Would this work for this if so how many would i need?
  14. Feb 26, 2012 at 5:16 PM
    tbone11212
    fayetteville NC
    07 Tacoma TRD 4x4
    no answer?
  15. May 23, 2012 at 6:47 AM
    DevL
    DevL Well-Known Member
    Can I turn on fogs with headlights off?
  16. May 23, 2012 at 7:02 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Yes and you don't need a brite box to do so. Search Fog Light Anytime Mod, it should be under the "Cheap/Free Mods" section under the 2nd Gen forum.
