High Mileage Club
Discussion in '1st Gen. Tacomas (1995-2004)' started by Lima004, Jun 2, 2015.
  1. Nov 5, 2015 at 8:49 PM
    58jake
    58jake Active Member
    Jake
    Three Forks, Valley Center, Kea'au
    1996 xtracab 4wd 3.4 auto with 296k. But I'm also cheating. A buddy of mine bought it from the original owner with a bad engine. He stuck a junkyard motor in it to turn a profit but I got to him first and got a smoking deal on it.
  2. Nov 8, 2015 at 10:42 PM
    Dcsleeper408
    Dcsleeper408 Well-Known Member
    Mark
    San Jose
    2000 Sr5 xtra cab
    Fishing pole antenna
    Clocking in 185k soon. Been using the mobil1 hi mileage 5100 oil every 5k with Bosch premium filter. what oil is everyone running?
  3. Nov 8, 2015 at 11:17 PM
    SanClementeTac01
    SanClementeTac01 Well-Known Member
    Dylan
    San Clemente, CA
    2001 Tacoma 4cyl manual 4x4 275k miles
    Fox 2.0 TRD Rear Diff Locker KM2's Snugtop Shell
    279,XXX on mine! Replaced all valves at around 225k. Runs like a top.
    I use the same oil w/ OEM filter from Toyota.
    Dcsleeper408[QUOTED] likes this.
  4. Nov 9, 2015 at 12:48 PM
    2scars
    2scars Swollen Member
    Brandon
    RVA
    2003 TRD 4x4 Doublecab
    All-pro, T-G, Budbuilt, Warn, Tepui, Homefab rear bumper
    266K-ish
  5. Nov 10, 2015 at 10:14 AM
    chaco
    chaco Member
    Chase
    Evergreen, CO
    '99 SR5 manual chaco taco
    using Royal Purple High Mileage syn and Royal Purple filter, probably going to switch to oem oil filter on next change.
    Dcsleeper408 likes this.
  6. Nov 10, 2015 at 2:55 PM
    Dcsleeper408
    Mark
    San Jose
    2000 Sr5 xtra cab
    what's your oil change intervals on the royal purple. I've been considering that on my next change since they now carry it at walmart!
  7. Nov 10, 2015 at 3:32 PM
    chaco
    chaco Member
    Chase
    Evergreen, CO
    I'm going to be doing a first change of the RP here in the next week when I do my valve cover gaskets, at that point I'll be just a bit over 3k on this oil (but about 11 months). I've already got the filter, so i'll use that but from the oil filter comparisons I like that the oem has more filteration material, etc. I'll probably run this for 5,000 since I don't know previous service history of truck and RP recommends doing initial short(er) intervals to "flush" the system before going longer. It does seem like good synth oil for this truck, we used RP for our Subaru before selling that.
    Per the product description: "HMX can safely extend oil drain intervals up to 15,000 miles or 12 months in unmodified, mechanically-sound engines with proper filtration. When using HMX, Royal Purple recommends first performing two short clean-up drain intervals of 3,000 miles each with HMX to thoroughly clean the engine before extending drain intervals."
  8. Nov 10, 2015 at 7:45 PM
    97tacomajewel
    97tacomajewel New Member
    tim
    97 4x2 830000 miles
    original motor and transmission
    My 97 Tacoma just went over 838,000.. its the original motor never overhauled. The manual transmission has never been touched. Blew head gasket at 600,000. There was small crack in head so it was replaced but nothing else. I bought 2015 taco few months back since I know it wont last forever but im still running to see how far it will go.
  9. Nov 11, 2015 at 7:08 AM
    leftcoastgroovie
    leftcoastgroovie Active Member
    Glennville, Ca
    2016 Tacoma DBL cab 4x4
    my 2nd gen 08 Taco 4x4 V6 4.0 5 speed has 590,000 ... I think your 15 should do well also!
  10. Nov 11, 2015 at 7:32 AM
    ecotecin
    ecotecin Wait, whut........
    WV
    2014 DCSB sold (2020 Chevy Silverado Crew Cab)
    Makes me feel good about buying my 2nd gen, with all these high mileages on them.
    leftcoastgroovie likes this.
  11. Nov 11, 2015 at 9:29 AM
    Dcsleeper408
    Mark
    San Jose
    2000 Sr5 xtra cab
    Thats awesome!!
    Gotta post a picture of the cluster!
  12. Nov 12, 2015 at 4:53 PM
    Dcsleeper408
    Mark
    San Jose
    2000 Sr5 xtra cab
    185k Just did a few things: new 2nd timing belt, new water pump, new belt tensioner, new thermostat, new radiator, Upstream o2 sensor, new deck, speakers, new ko2's 31x10.5 r15's, new oem pads,led interior(except cluster), fresh differential/transmission/transfer case flush OEM fluids.
    Oil change next week. Still on the fence with the Royal Purple. Might just stick to the Mobil1 Hi Mileage.
    Planning to get some black housing lights. debating whether i should do retro or leave halogen with some Silverstars
    Gotta repaint the grill. And then Give it a good polish when I get some time off of work.
    .....now time to play with my tundra.. Retrofitting that next month! So juiced!
  13. Dec 22, 2015 at 2:59 PM
    NM Lance
    NM Lance Well-Known Member
    I just hit 200K early today.
    2003 SR5 4X4 Access Cab V6
    No significant issues to report...
    3rd timing belt (no issues, just preventative maintenance)
    3rd water pump (no leaks or failures)
    3rd set of tires (OEM, Big O Pathmax, Duratrac's)
    2nd power steering pump
    2nd set of shocks (Bilstein 4600's)
    I have religiously used cheap/on-sale oil and cheap oil filters. I usually change oil every 4000 miles or so. Compression is 85%+ on worst cylinder.
    Original rear brake shoes and O2 sensors.
    I sold my Scouts II's and K5 Blazer to get into a Tacoma, no regrets at all. My Tacoma is just as capable, plus it has a pickup bed!
    I am hoping for another 100,000 miles, but I will see what I can get.
  14. Dec 22, 2015 at 5:10 PM
    1redcummins
    1redcummins Member
    332xxx here!
    NM Lance likes this.
  15. Dec 23, 2015 at 8:13 AM
    #35
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
  16. Dec 23, 2015 at 4:44 PM
    #36
    JKU3000
    JKU3000 Well-Known Member
    Birmingham, Alabama
    2014 Tacoma
    Almost at 200k!! Can't wait!
  17. Dec 24, 2015 at 2:37 AM
    #37
    98tacoma3rz
    98tacoma3rz Well-Known Member
    lancaster, pa
    2002 Double Cab Trd
    Did you replace the valves as preventative maintainence or were you having problems?
  18. Dec 24, 2015 at 2:38 AM
    #38
    98tacoma3rz
    lancaster, pa
    2002 Double Cab Trd
    220k on my regular cab 2.7. Replaced head gasket and a u joint beside PM.
  19. Dec 24, 2015 at 2:41 AM
    #39
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    buy some seat covers, new truck. sweet ride.
  20. Apr 1, 2016 at 11:24 PM
    #40
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    Just rolled 160K on the 04 DC. Original timing belt, water pump etc. Replaced hoses and thermostat, flushed radiator. Everything else has been touched and replaced at some point... Zero issues.
