High Mileage Maintenance (Items not listed in Maintenance schedule)
Discussion in '1st Gen. Tacomas (1995-2004)' started by Snowman94, Apr 5, 2017.
  1. Apr 5, 2017 at 9:54 PM
    Snowman94
    Snowman94 [OP] Member
    Charlotte, NC
    2000 Prerunner 282K (sold) 2001 Limited DC TRD-OR V6
    Greetings Yota Sages! I would humbly solicit your wisdom!
    I have a 2000 Prerunner 2.7. Runs like the day I inherited it from my Great-Grandfather at
    61k, it now has 194k. I used to trust whatever mechanic I took it to, but after finding my maintenance schedule and looking at wisdom on here I noticed that my mechanic "inspected" my truck every oil change, but never, in the entire 133,000 miles I've taken it to him, has he ever reccomended new Coolant, new ATF, new PS fluid. Also valve cover gasket was leaking and he didn't tell me. Thanks google. they say they check all fluids and inspect! BS. I learned how to maintain my Truck as of a few months ago, and it is now up to date according to the manual.
    However, are there any other items that, if I was, say, bored, or wanted to be extra careful, I could look at inspecting/replacing as a cautionary measure. Are there things you guys do that isn't in the manual, especially considering the high mileage?
    This Truck has cost me so little money in the 6 years I've owned it's ridiculous. I want to stay ahead of the game and take care of her.
    jammer, DustStorm4x4 and Dalandser like this.
  2. Apr 5, 2017 at 10:08 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    Toyota's are built to last. Change the oil, serpentine/timing belts (1st gens), differential fluid, coolant, spark plugs, clean the throttle body (MAF too), and grease the u-joints on the driveshaft. Otherwise, keep on driving and inspect every oil change.
    TRDSport10 and blairrad like this.
  3. Apr 5, 2017 at 10:22 PM
    Snowman94
    Charlotte, NC
    Ok. Didn't know about Throttle body and MAF. Just check and clean when dirty or is there a recommended interval?
    Thanks for the tip!
    ZachPrerunner[QUOTED] likes this.
  4. Apr 6, 2017 at 1:57 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    MAF is so easy might as well do it any time you're under the hood for anything bigger than an oil change.
    Snowman94[OP] and blairrad like this.
  5. Apr 6, 2017 at 6:43 AM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    No need to change the timing belt. You don't have one. You have a timing change. Which unless it's really stretched is just fine.
    Snowman94[OP] likes this.
  6. Apr 6, 2017 at 6:51 AM
    blairrad
    blairrad Yoter
    Missouri
    This, very much this. Toyota's are tough and will most likely die to rust before you can kill the engine. Unless you're stupid and don't do any maintenance whatsoever.
    Also, 194k isn't high. That truck's got way more life left.
  7. Apr 6, 2017 at 7:20 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    the mileage isn't as harmful as age. It's 18 yrs. old this yr.
    Everything rubber is getting to the end of it's life.
  8. Apr 6, 2017 at 7:45 AM
    Holy schmidt
    Holy schmidt Well-Known Member
    Wyatt
    Nebraska
    Every ~100k people tend to change lower ball joints (oem only). So id check those and upper ball joints
    Snowman94[OP] and Jalockett like this.
  9. Apr 6, 2017 at 7:49 AM
    ZachPrerunner
    Southeast TN
    I check and clean mine every 30-40k.
    Snowman94[QUOTED][OP] likes this.
  10. Apr 6, 2017 at 7:50 AM
    ZachPrerunner
    Southeast TN
    Correct, that's why I put (1st gens) in parentheses. OP has a 2000, so his does NOT have a timing belt.
    EDIT: Realized OP has 4 cylinder and not 6.
  11. Apr 6, 2017 at 7:55 AM
    Sicyota04
    Morgan
    California
    04 DC 4x4
    A 1st gen Pre runner w/ a 2.7 has a timing belt? Did not know that. Thanks!
  12. Apr 6, 2017 at 7:55 AM
    Jalockett
    Jalockett Well-Known Member
    Joshua
    Houston, TX
    '11 Prerunner V6 Sport
    Fire Department based modifications
    This. Ima bout to do this on mine. It is right at 100k, but I don't have a press so I may try to find full assemblies.
  13. Apr 6, 2017 at 8:36 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
  14. Apr 6, 2017 at 8:59 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Not true. The 1st-gen 6-cyl has a belt, the 4-cyl has a chain.
  15. Apr 6, 2017 at 9:49 AM
    Sicyota04
    Morgan
    California
    04 DC 4x4
    Correct! But some guys won't listen. I'm not here to argue. I know what I know
    TRDSport10 likes this.
  16. Apr 6, 2017 at 10:45 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Just to be clear, not all 1st gens have a Timing belt. @tan4x4 is correct.
    The OPs info states he has the 2.7L motor. This motor has a timing chain that does not require 'regular' maintenance. This is different from the v6 3.4L in 1st gens.
  17. Apr 6, 2017 at 11:13 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    The 4 Cylinder 2.4l 2RZ-FE and 2.7l 3RZ-FE both have timing chains, and not belts. The guides usually wear out before the chain, and you rarely need to replace the chain. If I'm not wrong the timing chain was made to last the lifetime of the engine.
    The 3.4l v6 5VZ-FE has the timing belt which periodically needs to be replaced.
  18. Apr 6, 2017 at 11:42 AM
    TacomaJunkie8691
    TacomaJunkie8691 1999WineTacoma
    WA State
    1999 Wine Tacoma SR5 Exta-Cab 4wd V6
    Completely Stock except for Ranch 5000 Shocks and Struts.
    Dear John from South Carolina,
    This is the maintenance scheduled I do with our old Tacoma, which is now older than hell, and it still runs like a Swiss Watch at 168,xxx miles on it. Some of the stuff I am going to list, you have already done so I apologize for the redundancy. This is the basic stuff. I had to change the valve cover gaskets on mine about two years ago too.
    1. Change the oil and oil filter every 4,000 miles if you are using Dinosaur Blood for oil. If you are using a full synthetic motor oil change out your oil and filter every 6,000 to
    7,000 miles. Try to use synthetic motor oil. It is a much better lubricant.
    2. Change your coolant every 30,000 miles or every 3 years, which ever comes first.
    3. Change out your the lubricant in your differentials, transfer case and manual transmission every four years if you are using full synthetics. If you are using regular lubricant,
    you might want to change these lubricants every two years.
    4. If you have an automatic transmission, do a full service every other year with new fluid.
    5. Change your spark plugs every two years, and change out your spark plug wires every other time, you change out your spark plugs.
    6. Replace the fuel filter every two years.
    7. Change the air filter whenever it is dirty. Check it once a year.
    8. Change out the power steering fluid every two years.
    Good Luck,
    Paul
  19. Apr 6, 2017 at 11:46 AM
    Snowman94
    Charlotte, NC
    Yeah, Manufactured June 2000, so 17 years old in a few months. So you would maybe recommend replacing some of the hoses, maybe CV boots, that kind of thing?
  20. Apr 6, 2017 at 11:50 AM
    Snowman94
    Charlotte, NC
    Will do! Is that something a reasonably intelligent person who can read instructions on youtube can do himself? (I'm quite poor) or should I maybe buy the parts and take them to my mechanic for him to do?
