High Mileage Oil
Discussion in 'Technical Chat' started by A_Ninja_Racer, Feb 20, 2013.
  1. Mar 15, 2014 at 9:12 AM
    GuyWithCamera
    GuyWithCamera Well-Known Member
    Alan
    Tracy,CA
    Nissan 370Z
    Just 5 days shy of a full year on this thread bump...
    I'm at 101K miles now on the X-Runner and 87K miles on the Impala, Still no leaks using Royal Purple 5w30...
  2. Mar 15, 2014 at 1:59 PM
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    Good to hear.
  3. Mar 15, 2014 at 2:10 PM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Mobil1 since day 1. 91K miles no intention of changing:cool:
    High mileage oil=snake oil:eek:
  4. Mar 15, 2014 at 2:31 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Just tons of hyper bole it's just oil with a different label.
    Lester Lugnut likes this.
  5. Mar 15, 2014 at 2:59 PM
    14TACO4X4
    14TACO4X4 Mmmmm... Beer
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    Crow Horse likes this.
  6. Mar 15, 2014 at 4:11 PM
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    Don't do it.
    Once you use HM oil and swell the seals and gaskets, you will likely have to continue using the HM oil to prevent new oil leaks.
    Unless you are having issues with seals and gaskets that the conditioners in a HM oil would possibly help with, I would not use it.
    I am still using regular Mobil 1 Extended Protection 5W30 in my 2006 at 354k miles with zero problems or leaks.
  7. Mar 15, 2014 at 4:22 PM
    dafloydboy
    dafloydboy Well-Known Member
    M.L. Evans
    lancaster s.c.
    15' base access cab
    Are camper shell
    Agreed, if it ain't broke don't fix it. I wouldn't use HM in a lawn mower. Just my2c
  8. Mar 15, 2014 at 4:25 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    The additives are slightly different.
    The Mobil-1 high-mileage does not meet the same "green" certifications for fuel economy.
    Likely, added viscosity improvers to hold heavier grade for the 10k most synthetic users are sold on.
  9. Mar 15, 2014 at 4:42 PM
    qnyla
    NM
    The Mobil 1 High Milage oil is API SL-rated rated while normal Mobil 1 is API-SN rated, a newer standard with lower levels of zinc as an anti-wear additive. The higher levels of zinc anti-wear additives can reduce the life of catalytic convertors, which is why the newer standards allow less of it.
    The viscosity of HM oils do not hold up longer than typical synthetics, all of which can easily go 10k miles in most engines.
  10. Mar 15, 2014 at 8:08 PM
    AlanLoshbaugh
    AlanLoshbaugh Well-Known Member
    Alan
    Columbia, MO
    2013 Tacoma Double Cab 4x4
    This was a great read, thanks.
  11. Mar 16, 2014 at 4:19 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Pretty smart stuff it knows the difference between paper gaskets and rubber seals and acts accordingly! There are more brands of oil on the market then cereals every one of them screaming buy me I’m the latest and greatest it’s the same thing as pure synthetic that isn’t.
  12. Mar 16, 2014 at 5:31 AM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    I just switched to all synthetic in my rider anxious to see if it runs any better this year.
  13. May 15, 2015 at 7:12 PM
    nicraknes
    nicraknes Member
    Peter
    Orlando
    Tacoma 1998
    I have just hit 350.000 ...
  14. May 15, 2015 at 7:25 PM
    qnyla
    NM
    Congrats. What model year is your truck?
  15. May 15, 2015 at 8:57 PM
    #35
    Master_Yota
    Master_Yota Well-Known Member
    Northeastern U.S.
    2017 Toyota Tacoma OR
    What is the number one recommended oil for the Tacoma. From Toyotas perspective and users here. Thanks.
  16. May 15, 2015 at 8:59 PM
    #36
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    Mobil 1 by a mile
  17. May 15, 2015 at 9:28 PM
    #37
    Master_Yota
    Northeastern U.S.
    Is that what Toyota recommends or just your choice.
  18. May 15, 2015 at 9:53 PM
    #38
    BaconPower
    BaconPower Well-Known Member
    Portland, OR, USA
    2013 Double Cab 4x4 TRD Offroad
    Just watch this:
    Regular oil changes with normal Mobil1 coupled with good quality gas is all you ever need.
    "I heard a commercial on the radio..." followed by "high mileage", then "after 75,000 miles" all in the same sentence does not sound trustworthy. That guy lost me at "75,000 miles is high mileage".
  19. May 16, 2015 at 2:32 AM
    #39
    qnyla
    NM
    Mobil 1 is my choice since the first miles when the truck was brand new on day 1. Now have 387k trouble free miles, no sludge, no oil burning.
  20. May 16, 2015 at 3:49 AM
    #40
    Mongo1958
    Mongo1958 Well-Known Member
    Van
    Newnan, GA
    2015 Bright White Access Cab w/convenience pkg.
    Carbon filter removal. Intermittent Wiper Stalk. Cruise Control. Fog Lights.
    To prevent carbon build up.
