High Mileage Truck Maintenance
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BrewTuna, Jan 24, 2025.
  1. Jan 24, 2025 at 2:26 AM
    BrewTuna
    BrewTuna [OP] Member
    08 DCSB TRD Sport
    First time, long time. I just picked up an 2008 DCSB TRD Sport from my father in law. Truck has 272k on it and runs like a champ. Father in law kept a log of all the maintenance and it’s been well taken care of.
    Since I’ve had it, I’ve changed the drive belt, idlers, and tensioner puller. And I have done the plugs and wires.
    What else should I be looking to do for preventative maintenance?
    I am going to do the coolant next. My father in law just used green coolant and it seems to have worked fine. Should I stick to green or flush and fill with pin?
    He suggested that I replace all the coolant/water hoses. I could probably do upper/lower radiator but that’s where my expertise ends. What else would I be looking for?
    Some other issues:
    There is a small fluid leak coming from the driver side axle. I’m assuming that a bearing that needs to be replaced.
    I’ve also noticed a whooshing sound at low speed when making a sharp turn.
    Thanks!
    lynyrd3 likes this.
  2. Jan 24, 2025 at 4:17 AM
    lynyrd3
    Bill
    East Central Upstate NY
    Coolant flush and put the right stuff in . Thermostat , brake fluid flush and replace . Maybe just a drain and fill at the trans pan if your an automatic. 4wd ? Transfer case fluid change ,both differentials . Make sure your greasing the u joints in the drive shaft .
    wi_taco and POOLGUY like this.
  3. Jan 24, 2025 at 8:20 AM
    BrewTuna
    08 DCSB TRD Sport
    Luckily, he did the diffs, transfer case on regular intervals.
    transmission scares me, like because of the miles and loss of friction if I do it. It’s running fine.
    lynyrd3 likes this.
  4. Jan 24, 2025 at 8:53 AM
    Peter603Taco
    Peter603Taco Well-Known Member
    Peter
    New Hampshire
    2013 TRD Sport DCLB
    Recently did a pan drop, clean magnets, replace strainer/filter, and then 3 drain and fills over 500 miles on my 13 with 190k since I'm planning on driving it for as long as possible. Like you I was worried of doing it due to the miles and never being done, but it definitely shifts smoother now. I kept all the old fluid so I could "switch it all back" in case of loss of friction and slipping but that was a couple thousand miles ago so I think I would have seen it by now. YMMV but just figured I'd give my experience. I would def not do a true power flush, I tried to do it the most "gentle" way.
    lynyrd3 and clenkeit like this.
  5. Jan 24, 2025 at 11:32 AM
    lynyrd3
    Bill
    Right ,no power flush . Drop pan clean magnets before if you do . Or just the drain and fill method like you did :thumbsup:
  6. Jan 24, 2025 at 6:07 PM
    Biblebuilt4x4
    Biblebuilt4x4 Well-Known Member
    Bill
    2014 Reg. cab 4x4 automatic
    Also might consider a power steering fluid flush.
    lynyrd3 likes this.
  7. Jan 25, 2025 at 10:49 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I always replace the oem fluid with universal coolant. StopTech has on the label the coolant ingredients required by Toyota. At 200K I replaced the radiator and water pump, and the bypass hoses, for preventive maintenance and my peace of mind. Also the fan and fan clutch, and thermostat.
    lynyrd3 and TacoDell60 like this.
  8. Jan 25, 2025 at 2:50 PM
    BrewTuna
    08 DCSB TRD Sport
    My goal would be to get all that done but the water pump and bypass hoses are beyond my pay grade.
    lynyrd3 likes this.
  9. Jan 25, 2025 at 3:13 PM
    JAGCanada
    JAGCanada Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
    I'll be replacing my fan/clutch as I get closer to 200k miles. Seen a few pics of fans letting go and causing a lot of collateral damage.
    lynyrd3 likes this.
  10. Jan 25, 2025 at 4:06 PM
    Chuy
    Lakeside, CA
    Silver Taco
    Stick with Aisin parts, the OEM manufacturer. Pricing was not too bad on rockauto. For hoses I went with Gates. The radiator was CST, the single roe, not the pricey aluminum one they have for Tacomas.
  11. Jan 25, 2025 at 8:45 PM
    ShimaMaelstrom
    ShimaMaelstrom Member
    Yoshi
    Front Range Colorado
    2006 White 4.0 Tacoma Access Cab
    Check your ujoints and anything suspension. Preventative maintenance is key :)
    lynyrd3 likes this.
  12. Feb 4, 2025 at 3:51 AM
    lynyrd3
    Bill
    My Truck has 166K . In need of cleaning throttle body and MAF . Also new plugs . Think the plugs have been changed only once . Have to check my records. Never did throttle body or MAF
