High NOX levels for smog check.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Meanahyotruck, Mar 1, 2016.
  1. Mar 1, 2016 at 6:37 AM
    Meanahyotruck
    Meanahyotruck [OP] Member
    Duke
    Cardiff
    98' with 33"s lumber rack and box of tools
    6 inch ome kit 18" rims
    So went in for my smog check and my NOX level was double the standard. We ran the obd and no code came up. I checked the plugs and they are pretty new. Checked vacuum lines they seemed ok. Ran a sea foam system clean in fuel and intake. The levels came down but still too high. Changed the spark wires and coils. It came down a little more. Determined it was the catalytic conv. Got a whole new cat, pipe and flow master. Ran it on a dyno now it's back to where I started at double the standard at 1100. Any suggestions?
  2. Mar 1, 2016 at 1:17 PM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    Might wanna check your egr valve. If there is one not sure. But a bad or not hooked up correctly egr will cause high. Nox.
  3. Mar 1, 2016 at 11:27 PM
    Meanahyotruck
    Duke
    Cardiff
    Cool thank you lefty. Do you have a procedure for testing?
  4. Mar 1, 2016 at 11:44 PM
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
    Hummm. No.lol my experience is with jeeps to be honest. If their similar you can test it with a vacuum gauge to see if the diaphragm moves. Otherwise I got nothing sorry. You could look in FSM and see if there's a procedure. It's linked in the stickys.
