High octane fuel due to turbo?
Discussion in '4th Gen. Tacomas (2024+)' started by 05Taco4x4, May 21, 2023.
  1. May 21, 2023 at 12:37 PM
    05Taco4x4
    05Taco4x4 [OP] ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    Has anyone seen fuel octane requirements?
  2. May 21, 2023 at 12:54 PM
    Clearwater Bill
    Billy
    Largo Florida
    Lots of OE turbos do not.
    Depends on many variables.
    My *guess* is no, because it would dampen sales.
    Which means fairly low boost, small turbo to hit peak at low RPM and being well managed fuel, spark. Etc by the ECU
    SH10151 likes this.
  3. May 21, 2023 at 4:48 PM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    In the ford ecoboost manual it states on page 252, “For best overall vehicle and engine performance, premium fuel with an octane rating of 91 or higher is recommended."
    Ford ecoboost 2.0 - The engine in your vehicle has been optimized for operation using 95 octane unleaded gasoline that meets the specification defined by EN 228 or the equivalent national specification.
    Ford is a big market with ecoboost.
  4. May 22, 2023 at 7:34 AM
    twtaco$
    twtaco$ Well-Known Member
    I had a v8 with 10#s boost required 93 weird a small 4 cyl guess it’s 5# boost is ok in 87.
    Don’t get stuck in the mud may blow it up.
  5. May 22, 2023 at 7:48 AM
    GBR
    GBR Well-Known Member
    19 TRD OR
    Are you quoting a European manual? If so, that translates to 87 octane and up is fine and 91 will get you improved performance over 87.
  6. May 22, 2023 at 10:41 AM
    DeuceDeuceBravo
    DeuceDeuceBravo Well-Known Member
    New England
    It's not just the amount of boost; it's also controlling all the variables like timing, air/fuel ratio, etc. A modern ECU with all the accompanying sensors can handle a turbo and 87 octane. Putting 87 in an older car, even like 10-15 years old, would be a bad scene.
    tonyrocco and dleithaus like this.
  7. May 22, 2023 at 7:15 PM
    NoDak
    NoDak Well-Known Member
    JR
    Minot, ND
    16 Tacoma TRD Sport 4x4 Blazing Blue
    on toyota's usually in stock tune
    87 will pull about 10 degrees of timing, 6-8 on 89, and 0-2 degrees on 91+ (i think, per someone else's post on another forum)
    turkeyslayer66 likes this.
  8. May 29, 2023 at 5:25 PM
    05Taco4x4
    2TR-FE Enthusiast
    I viewed one of the Hawaii reveal videos and the gas cap was shown, the reporter noted regular 87 fuel. Case closed.
  9. May 30, 2023 at 6:05 AM
    turkeyslayer66
    turkeyslayer66 Well-Known Member
    mike
    22 AG Trd Sport
    87 octane will result in reduced performance vs 93 in a turbocharged/supercharged motor. Sure, it may be rated to run on 87, but the engine management is going to pull timing and boost to prevent detonation.
    dleithaus and terryhutchinson like this.
  10. May 30, 2023 at 6:48 AM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    Won't really be any benefit to run 93 in an 87 minimum engine. You'll basically spend more and possibly get slightly worse fuel milage.
    Hogleg918 likes this.
  11. May 30, 2023 at 7:12 AM
    Hogleg918
    Hogleg918 Well-Known Member
    Oklahoma
    Ranger Raptor, sorry TW
    2024 and Toyota still using gas caps, what is the world coming to?
  12. May 30, 2023 at 7:51 AM
    AspektZA
    AspektZA Member
    2017 BMW 340i
  13. May 30, 2023 at 7:56 AM
    stevesnj
  14. May 31, 2023 at 7:47 AM
    terryhutchinson
    terryhutchinson Well-Known Member
    Terry
    2023 Tacoma TRD Off Road
    It's not always about the money for some of us. The engine may run smoother and provide a slight bit more boost with premium. That's really the question here. Not whether or not premium is worth the price from purely an mpg perspective.
    Junkhead likes this.
  15. May 31, 2023 at 8:11 AM
    stevesnj
    Well the gains are minimal was my point since these turbo engines that aren't high revving high HP usually have lower compression ratios. We will see.
  16. May 31, 2023 at 9:09 AM
    AspektZA
    AspektZA Member
    2017 BMW 340i
    Depends on where you live.
    Here in Colorado, using 85 in a turbo vehicle isn't the best idea per se.
    https://www.youtube.com/watch?v=kJyd6C99_3g
    Higher octane in a turbo engine is always welcomed, and has a noticeable impact no matter the altitude.
    You won't notice it in a 2nd or 3rd gen Taco as those come from the factory with a 50hp delete here - or 90hp if you're at the Eisenhower tunnel!
    GBR likes this.
  17. May 31, 2023 at 9:13 AM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    Might be minimal, might not. My wife’s Mazda gives 30hp extra on premium per their official docs. That’s pretty significant
