High or low Octane
Discussion in 'Technical Chat' started by TRDeity, Jan 25, 2007.
  1. Jan 25, 2007 at 1:10 PM
    TRDeity
    TRDeity [OP] Well-Known Member
    ATX
    2017 TRDpro
    I'm just about to fill up my tank for the first time and was wondering what octane rating everyone out there was using. I was flipping through the manual and found that all Toyota's specs (such as HP and MPG) were done using 91 octane, but you only need 87. Has anyone noticed better MPG with a higher octane or had any notably better performance?
  2. Jan 25, 2007 at 1:28 PM
    topdec
    topdec Well-Known Member
    I use 89. Middle of the road. Get some performance but not too expensive.
  3. Jan 25, 2007 at 4:40 PM
    SAM
    SAM Member
    I have been using 87 octane, but tried 91 for three consecutive tanks last summer and never noticed any measurable difference in mileage. My engine doesn't knock with 87 Octane and I dídn't notice any performance gain with my truck and 91 Octane. I have around 5 000 miles on my truck.
    I was getting 23 mpg (HWY) and 18-19 mpg (city) during the summer months running 87 octane in my 2006 Dcab LB 4X4 Auto.
    SAM
  4. Jul 28, 2007 at 12:19 PM
    sunruner19
    sunruner19 Senior Senile Member
    Bill
    Great Sacandaga Lake region Northville NY, South Y
    09 Tacoma 4WD
    supercharger, ARE series 2 lid.
    With the exception of the x runner, all toyota tacoma engines are designed to run on 87 octane. However it doesnt hurt to use the high test gas every once in a while.
  5. Jul 28, 2007 at 12:53 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i run midgrade or high test all the time nowadays. it may be a couple dollars more expensive when you fill up, but i can tell a significant difference between the high test and regular. truck runs smoother and idles better on the good stuff, imo.
  6. Jul 28, 2007 at 3:30 PM
    SLOTaco
    SLOTaco Ultimate Member
    Central Coast, California
    06 TRD Sport
    '06 TRD Sport 4x4 AC, K&N drop in air filter, Magnaflow cat back, Bilstein 5100's with Toytec adjustable front coil over 3" lift, rear TSB, AllPro UCA's.
    I agree, the high test is good because it not only has higher octane but also more detergents and such. My butt dyno tells me that my tuck runs best on mid grade, I've tried them all and 89 seems to work the best. I put a tank of 91 in every once and a while just for good measure.
  7. Jul 30, 2007 at 8:57 PM
    dudebuddy26
    dudebuddy26 New Member
    I run midgrade as well always had in my 03 for 60,000 miles now, my father borrowed it not to long ago, put regular in it and I could tell a HUGE difference, I knew immediately, It may not really make a difference now but down the road, your yoter will thank you and treat you the same
  8. Jul 30, 2007 at 9:29 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    I too have tried them all and i have noticed a difference, 91 is the best but gas prices in cali suck ass but what can you do, i run 89 and its very good for my truck and that what i mainly run, 87 is ok but i can tell the difference in performance.
  9. Jul 31, 2007 at 4:18 AM
    Panama Red
    Panama Red Well-Known Member
    This may explain the ongoing debate as to which Octane Rating to use:
    1GR-FE 4.0L V6 from a 2007 Toyota Tacoma. The 1GR-FE is the 4.0L version. Bore is 94 mm and stroke is 95 mm. Output is 236 hp (183 kW) at 5200 rpm with 266 lb-ft (382 Nm) of torque at 4000 rpm on 87 octane, and 239 hp at 5200 rpm with 278 lb-ft at 3700 rpm on 91 octane. This engine features Toyota's single VVT-i, variable valve timing, system and a compression ratio of 10.0:1. Inside, the 1GR uses a taper-squish combustion chamber design with matching pistons to improve anti-knocking and engine performance, while also improving intake and fuel efficiency. Toyota adopted a siamese-type intake port, which reduces the surface area of the port walls and prevents fuel from adhering to such walls. This engine has special cast-iron cylinder liners cast into the block, which are a spiny type to improve adhesion between the liner and cylinder block. With these special thin liners it is impossible to bore the block. In the event of cylinder wall damage (scoring, deep protrusions, etc), the entire cylinder block must be replaced. For increased block rigidity, the 1GR also receives a high temperature plastic insulator/protector, which fills the empty space between the outer portion of the cylinders and block material common to open deck engines. For increased cooling efficiency, the 1GR employs water passages between the bores of the engine. There are such 2 passages for each bank for a total of 4. This reduces cylinder hot-spotting and keeps combustion chamber temperatures more uniform.
    Some applications:
    2003 Toyota 4Runner
    2003 Toyota Land Cruiser (Europe)
    2005 Toyota Tacoma
    2005 Toyota Tundra
    2005 Toyota Fortuner (Middle East)
    2007 Toyota FJ Cruiser
    2007 Toyota Tacoma
    loaded1911 likes this.
  10. Aug 8, 2016 at 12:29 AM
    jgtovr
    jgtovr New Member
    Jesus
    Toyota Tacoma TRD
    Lots....
    I have used 91octane on my 2015 tacoma since I bought it... and it has 30k miles now... with not problems but I am worried after reading most comments about engine damage etc... O well I don't want to just add 89oct I feel I might mess it up stepping down to a lesser octane...
  11. Aug 18, 2016 at 9:30 PM
    BlindingWhiteTac.
    BlindingWhiteTac. Well-Known Member
    Thomas
    Vancouver, WA
    07 LQ4 4L80E
    Just the essentials and no extra fluff.
    Wow!!! 12 extra torques!!!
  12. Aug 18, 2016 at 9:38 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    You won't damage these Toyota engines by running lower octane fuel. Higher octane in most modern engines will result in slightly higher peak horsepower and torque numbers but not by much. The ECU simply adjusts timing to take advantage of the higher octane fuel resisting detonation longer.
    98tacoma27 likes this.
