High Performance 4.0 V6 Motor?
Discussion in 'Performance and Tuning' started by VABUCKAROO, Jul 7, 2012.
  1. Jul 14, 2012 at 8:55 PM
    #61
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    I see, makes sense. :cool:
  2. Jul 14, 2012 at 8:57 PM
    #62
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    All good brother. :thumbsup:
  3. Jan 23, 2016 at 8:02 PM
    #63
    Bobby vanover
    Bobby vanover New Member
    Bob
    double cab4x4tacoma sr5
    None
    Just starting to work on trying small things to motor first
  4. Jan 23, 2016 at 8:05 PM
    #64
    Bobby vanover
    Bob
    None
    What are some of the better things to try fist
  5. Jan 23, 2016 at 8:42 PM
    #65
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    headers, ypipe, exhaust, intake, maf calibrator, blower.
  6. Jan 24, 2016 at 5:19 PM
    #66
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    How far are you willing to go?
    Justus likes this.
  7. Jan 24, 2016 at 7:03 PM
    #67
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    not as far as u im betting
    Torspd[QUOTED] likes this.
  8. Jan 25, 2016 at 6:19 AM
    #68
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Only race teams are.....or people with race team monies...
  9. Jan 25, 2016 at 2:35 PM
    #69
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    :eek: :thumbsup: :rofl:
    Keep some budget for the pills. It's a very dangerous disease.
  10. Jan 25, 2016 at 2:56 PM
    #70
    Tacoma SS
    Tacoma SS Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    That sounds exciting
  11. May 8, 2020 at 11:32 AM
    #71
    ljma90
    ljma90 Well-Known Member
    Jordan
    2007 Toyota Tacoma v6 4x4
    2.5 inch suspension lift front with rancho 9000 quick lift struts, rear rancho shock absorbers with 2.5 inch sky jackers add a leaf springs in rear. extra 2 inch long braided front brake lines with radiator flush, transmission flush, brand new front brake rotors, calipers, and shoes all done myself. more to come
    @Torspd you ever get those Kelford cams? I was thinking about seeing if they can make me up a set. Sent them a email and waiting for response. Also was wondering about the 71lb or 61lb dual springs, which to get? I won’t be going s/c until next year. But I am going with everything else. Also on lifters, you running with just the oem lifters? I’ll be going 1mm oversized on the intake and exhaust valves
  12. May 8, 2020 at 12:14 PM
    #72
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Supertech oversized valves. OEM lifters. Kelford will tell you which springs they recommend.
    We had a group-buy, last year. Some other members have ordered from them more recently this year.
    Kiel is pretty much the man that you need to talk to.
    HomerTaco and ljma90 like this.
  13. May 8, 2020 at 12:43 PM
    #73
    ljma90
    Jordan
    Thank you thank you
    Torspd likes this.
