High pitch squeal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cmans4x4, Dec 30, 2024.
  1. Dec 30, 2024 at 4:38 AM
    Cmans4x4
    Cmans4x4 [OP] Member
    15 Sport DCLB 4x4
    33’s
    Good morning everyone! I am experiencing a high pitch noise that starts around 30mph. Does not change with speed or changing direction. 2” lift and 32’s. The rest is stock. Possible wheel bearing? Tapping the brakes does not change it either.
  2. Dec 30, 2024 at 6:41 AM
    1 Limited Toyota
    1 Limited Toyota ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    Mine stopped immediately after the divorce.
    Ok thats not helpful
    It would have to be a constant that doesnt change like the what you said, the wheel bearing. Have you isolated it to the front/back, left/right, center? How many miles on the truck.
  3. Dec 30, 2024 at 6:45 AM
    Cmans4x4
    15 Sport DCLB 4x4
    33’s
    lol, thanks for the reply. The old girl has 193k. It is difficult to isolate where it is coming from riding in the truck. It sounds like a brake wear indicator but the rears were just done and the fronts are still good. And it does not stop when pressing the brakes.
  4. Dec 30, 2024 at 6:59 AM
    1 Limited Toyota
    California
    08 XRunner
    To be clear...
    1) Does the pitch change note or its just on/off?
    2) with engine rpm or vehicle speed?
    3) any idea of isolated area?
  5. Dec 30, 2024 at 7:14 AM
    Cmans4x4
    15 Sport DCLB 4x4
    33’s
    There is no change in the pitch. It starts after the truck is moving, close to 30mph, and continues. Best I can tell, it’s from under the truck. I know this is vague and not really helpful. I am mechanically inclined and do all my own work. I am planning to do some exploratory surgery to see what I can find. Just wasn’t sure if this was definitive of a wheel bearing.
  6. Dec 30, 2024 at 9:47 PM
    1 Limited Toyota
    California
    08 XRunner
    Wheel bearings or drive shafts usually change with speed of the car. Wheel bearings often change intensity or even go away on a corner as the load varies. Alot of times you can lift a wheel and spin it. If bad enough it'll make a gravelly grinding sound. Wheel bearings won't vary with engine rpm like an engine belt squeel.
    Cmans4x4[OP] likes this.
  7. Jan 1, 2025 at 10:35 AM
    Cmans4x4
    15 Sport DCLB 4x4
    33’s
    Well here is the update, a very tiny piece of rock was stuck between my brake pad and rotor. The pads were thick so initially I didn’t think that was the issue. Thanks for the input 1 Limited Toyota!
    1 Limited Toyota likes this.
