high pitch squeel noise in front end
Discussion in 'Technical Chat' started by hagar71, Jan 14, 2007.
  1. Jan 14, 2007 at 2:54 PM
    hagar71
    hagar71 [OP] Member
    im gettin a high pitched squeeling noise that almost sounds like an alarm, theres no alarm in so?? short in length doesnt happen at the time? anybody ever hear somethin so strange? I shut the radio off so i was hearin things...
  2. Jan 29, 2007 at 10:13 AM
    CharlieX
    CharlieX Well-Known Member
    When you're driving? Starting up? Braking? If it's not the brake pads getting worn too low, it could be a loose belt
  3. Jan 29, 2007 at 10:24 AM
    hagar71
    hagar71 [OP] Member
    The Noise Happens While Driving. The Almost Sounds Like A Car Alarm Sound But Very Quik. It Def Sounds Electrical?
  4. Jan 29, 2007 at 10:59 AM
    CharlieX
    Huh, I'm out of ideas... unless you have a car alarm in your Taco and there's a shorted wire that's causing it to beep intermittently???
  5. Jan 29, 2007 at 2:31 PM
    hagar71
    hagar71 [OP] Member
    See Thats The Thing...i Have No Alarm! Lol Weird Huh?
  6. Jan 29, 2007 at 3:02 PM
    2003greenbean
    2003greenbean Carolina Alliance Costal Div
    socaste,sc
    03 trd
    cold air intake, step bars, custom grill, 3in lift,12 in audiobahn sub, 285/75/16 procomp tires, 20% tint,
    5 speed or auto?
  7. Jan 29, 2007 at 6:28 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Belts squealing? That would be my guess but then I haven't heard what you're hearing.
    Have you popped the hood and tried listening around while the engine is running?
  8. Jan 30, 2007 at 2:29 AM
    greatone007
    greatone007 Member
    It is probably a wind noise if going over 60 miles an hour.
  9. Jan 31, 2007 at 8:02 PM
    hagar71
    hagar71 [OP] Member
    no was doin 25mph... i just cant figure it out...what does it sound like when brakes neeed to be replaced?
  10. Feb 1, 2007 at 4:56 AM
    2003greenbean
    socaste,sc
    03 trd
    hagar is your truck a 5 speed?
    the reason i ask is my cluth pedal made an awful noise when i first got it some grease helped but my throwout bearing makes a high pitched noise and it took me a long time to figure out what it was
  11. Feb 1, 2007 at 8:43 AM
    topdec
    topdec Well-Known Member
    Worn brake pads have a metal-to-metal grinding sound, but only when you apply the brakes...
    Intermittent problems are terrible to diagnose. Be careful when driving around and having your mind trying to figure it out.
    A while ago, I was involved in an accident while driving with a dealer tech. I wanted him to listen to the noise I heard from my Galant's cabin. We got into an intersection with only YIELD signs. I thought I slowed down to yield, so I proceeded to cross the intersection, while partially looking at what the tech was doing.
    My right fender got hit by a crossing car. The other guy was heading home from working a nightshift. But in the back of my mind, I know I could have avoided the accident if I was concentrated on the road the whole time.
  12. Feb 16, 2007 at 3:19 AM
    hagar71
    hagar71 [OP] Member
    it sounds almost like a short siren sound. the truck is an automatic and have heard the sound while sittin still as well as moving?? i have nooooooooooooo idea!
  13. Feb 16, 2007 at 11:55 AM
    TRDeity
    TRDeity Well-Known Member
    ATX
    2017 TRDpro
    I too would guess a belt. Is it still under warranty?
  14. Feb 16, 2007 at 12:54 PM
    BigBacon
    BigBacon Member
    i know what you are talking about..take it back to the dealer and see why its cutting on like that...it is a safty feature for speed..it is suposed to start making that noise at 110 mph. and not cut off untill you have reduced your speed.
  15. Feb 22, 2007 at 3:37 AM
    hagar71
    hagar71 [OP] Member
    do you think resettin the computer would help?
  16. May 20, 2010 at 1:26 PM
    fishinsteeg234
    fishinsteeg234 Well-Known Member
    Alex
    Atlanta, GA
    06 PreRunner Short Bed
    Pro Comp 3" suspension lift kit, Pro Comp 8128 alloy wheels with 285/75/16 BFG AT KO's, Gorilla Lugs, Camburg 1.5" uniball UCA's, AFE cold air intake, Black N-Fab bars, SS extended brake lines, HID bixenon's
    This is an old thread but i just heard that loud siren noise from under my truck too. i had just applied some brake parts cleaner on my brakes and put in fuel injector cleaner in my engine and took it for a spin. the siren went off twice, while i was driving at about 25mph and then stopped about 2 min later. now i haven't heard it again. what is this noise?
