High-pitch vibration at idle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Shiner, Aug 27, 2011.
  1. Aug 27, 2011 at 9:59 PM
    Shiner
    Shiner [OP] BAMF
    Spencer
    Pensacola
    08 SWB 4x4 Sport 6-speed
    None yet, other than wheels :)
    Got this taco used a few days ago and today I noticed that it puts out a faint but annoying high-pitch vibration when at idle. If I push the clutch pedal in the slightest bit it stops. Anyone had this problem?
  2. Aug 27, 2011 at 10:01 PM
    Tylerm5000
    Tylerm5000 Well-Known Member
    Tyler
    Oregon
    1995.5 2.7l reg cab 4x4 5-speed red pearl
    Alcan stock height 4-leaf springs, greaseable main eye bolts, OME greaseable shackles, all energy suspension bushings, 2-row extra deep radiator, KYB gas-a-just shocks. ALL LED exterior and interior lighting including custom tail lights and blinkers.
    Clutch slave cylinder pin probably needs lube on both sides.
  3. Aug 27, 2011 at 10:49 PM
    Shiner
    Shiner [OP] BAMF
    Spencer
    Pensacola
    I have no idea where that is but I'll try tomorrow haha
  4. Aug 28, 2011 at 11:34 AM
    Tylerm5000
    Tyler
    Oregon
    The clutch fork sticks out of the transmission. There should be a hydraulic cylinder (sometimes painted blue, black, or red) and it has a rubber boot on it. Push the fork back and pull the rod and boot clear off of the cylinder. Use care so you don't tear the boot. The rod needs moly grease on both ends. The end inside of the boot and the end that touches the fork. If that doesn't work, I would replace the whole slave. That is what I am doing. I just haven't gotten around to it yet.
  5. Aug 28, 2011 at 11:36 AM
    Tylerm5000
    Tyler
    Oregon
    It is extremely annoying. Mine also makes that noise when coasting with my foot off of the gas pedal. Like going down hill.
  6. Aug 28, 2011 at 1:11 PM
    Shiner
    Shiner [OP] BAMF
    Spencer
    Pensacola
    Thanks I'll try that...I'll let you know if it works
  7. Aug 28, 2011 at 1:19 PM
    chugchug
    chugchug Well-Known Member
    Will
    Frederick MD
    2012 Toyota Tundra
    Mine did the same thing. I found out that it was the throwout bearing was bad so I had it replaced and haven't heard it since. It is a big problem with manual transmission on the tacoma. Sorry if it is the same thing cause its not cheap.
  8. Aug 28, 2011 at 1:44 PM
    Shiner
    Shiner [OP] BAMF
    Spencer
    Pensacola
    How not cheap are we talkin?
  9. Aug 28, 2011 at 1:52 PM
    chugchug
    Will
    Frederick MD
    2012 Toyota Tundra
    Well when I bought it got the extended warranty on it they covered it. Since they had the tranny out I had them do the clutch since I didnt know how the other owners drove it. It totaled around 2 k and 400.00 of it was the clutch sorry to tell you that so I hope it is not the same for you
  10. Aug 28, 2011 at 4:50 PM
    Shiner
    Shiner [OP] BAMF
    Spencer
    Pensacola
    Does it cause any other problems other than the noise? I can only faintly hear it if I have the radio off and I can live with it without spending a few bills...However if it is going to develop into a bigger problem I will definetely get it fixed.
  11. Aug 28, 2011 at 4:55 PM
    chugchug
    Will
    Frederick MD
    2012 Toyota Tundra
    I was told that it could but not sure. I didnt have to pay for mine just the clutch so I had it done do a search on here to find it. they r pretty helpful here.
  12. Aug 28, 2011 at 6:58 PM
    Shiner
    Shiner [OP] BAMF
    Spencer
    Pensacola
    Ok, thanks for the help!
