High Pitch Whining Noise in Dash
Discussion in '1st Gen. Tacomas (1995-2004)' started by eidsondesign, Dec 22, 2020.
  1. Dec 22, 2020 at 2:29 PM
    eidsondesign
    eidsondesign [OP] Well-Known Member
    Dave
    2004 Green Tacoma SR5 Extended Cab TRD
    Have tried searching around but am not coming across anything that sounds familiar. I have a high pitch noise coming from what I can best describe as inside the dash.
    I can hear it when I am idling , it starts maybe 3-5 seconds after the car is started and increases and decreases when the throttle is pressed and released.
    Manual Transmission - but being in gear or out of gear has no impact, the sound is still present.
    Not coming through stereo.
    AC is off but when turned on the sound increases slightly.
    It sounds like its coming from either the steering column or directly behind the gauge cluster. There is a slight variance in tone when I turn the lights on and off.
    I do not hear it in when I open the hood, its only noticeable inside the car.
    My guess is that its something electrical but have no idea where to start ?
    Any help is appreciated.
  2. Dec 22, 2020 at 2:33 PM
    Clearwater Bill
    Billy
    Largo Florida
    Alternator bearings would be my first stop with a mechanics stethoscope, based on your description.
    Dm93 likes this.
  3. Dec 22, 2020 at 2:34 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Alternator. Yes it makes no sense.
  4. Dec 23, 2020 at 5:13 AM
    eidsondesign
    Dave
  5. Dec 23, 2020 at 5:31 AM
    Clearwater Bill
    Billy
    Largo Florida
    So you've confirmed the problem?
    My personal preference is to use a local electrical shop and have them rebuild the OE unit. I have often found it to be no more expensive than an OTC parts house reman and much more reliable, with a 'local' warranty.
    Black DOG Lila likes this.
  6. Dec 23, 2020 at 5:46 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    OEM alternators are far superior
    Rebuild yours
  7. Dec 23, 2020 at 10:40 AM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    if you don't have a stethoscope, a piece of wood closet pole transmit sound very well. Just put up against the side of the alternator and listen. If it's the bearing, you'll hear it loud and clear. I'd also look for a rebuild kit and fix it. I know the brushes are an easy fix, not sure how hard it would be to remove and press on new bearings. Good luck.
  8. Dec 23, 2020 at 11:43 AM
    treyus30
    Trey
    Mesa / AJ, AZ
    I went with the GM upgrade, but ya try to confirm somehow
    I was actually glad to upgrade, so I didn't spend too much time figuring out what failed in the OEM
  9. Dec 23, 2020 at 11:52 AM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    There are several upgrades that you can do, I've read several posts of people installing other branded alternators for more output.
