High pitch whistling noise in 2012?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by usmc91, Nov 27, 2011.
  1. Nov 6, 2013 at 5:27 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    read through this entire thread.
    i JUST bought a 2013 v6 auto DCSB 4x4 TRD off road... and have a very FAINT whistling noise... like a tea kettle starting to sound on the other end of the house. at 40+ mph
    is the rod / dowl / tube through the front grill seal going to fix this?
  2. Nov 6, 2013 at 5:31 PM
    Jhodgman
    Jhodgman ...
    Justin
    So Cal
    13 4x4 DCLB tacoma V6 TRD Sport
    5100 Bilstiens set at 1.75, progressive leaf pack, BFGs, All-Pro rear Bumper(white), Storm troopered out
    Same thing happened to me its the rubber above the grill under the hood. Easy fix is to go to homedepot and for a buck get 1/4" tubing and push it in the opening. Should fix it right away.
    You'll notice the rubber is really soft. That's what causes it to whistle when you drive at about 50-60
  3. Nov 19, 2013 at 8:06 PM
    Stoneb
    Stoneb New Member
    TN
    13 PreRunner TRD Sport Dbl Cab LB
    What a relief! I had the whistle in my 2013 as well until I found this thread. I used black air line tubing left over from a fish aquarium. Fed it with a metal coat hanger through the weather stripping between the hood and grill top. I also fed it through the weather stripping above the headlights but that may have been overkill. Its been two months since and no more noise! Love the simple and cheap fixes. Thanks to those that found this and shared the fix.
  4. Dec 2, 2013 at 4:29 PM
    moddy
    moddy New Member
    Williamsburg, VA
    base 4x4 Tacoma
    Worked like a champ. My 2013 Tacoma had the same issues. Thanks everybody
  5. Mar 20, 2014 at 11:56 AM
    ZimTaco
    ZimTaco Member
    Zombieland
    '25 TRD OR 6MT
    God this site is awesome. Had the same problem and solved it with some 1/4" poly tubing. THanks to all that said this worked for them. It solved my problem.
  6. Jun 1, 2015 at 2:58 PM
    carneasada
    carneasada JURASSIC TACO
    Reno
    2013 TRD OFF ROAD, BLACK DCSB
    Volant CAI, more comin !
  7. Nov 10, 2015 at 11:33 AM
    15TrdSportec
    15TrdSportec Well-Known Member
    2016 DCSB TRD Sport 4x4 Super White
    So my 2015 started to make this noise. Should I just take it to the dealer to have them deal with it or diy. Happens when I go 70-80mph. I thought it was the antenna because it was only on the passenger side
  8. Nov 12, 2015 at 12:45 PM
    carneasada
    Reno
    So I think I figured it out . I lossened my top two grill mount bolts and scooted the grill as foward as far as possible then tightened the hell out of the bolts so the grill wouldn't move and it totally fixed the problem .. I inserted a plastic tub before hand into the rubber seal to tighten the gap but that didn't fully do it .. So I don't know if it's a combo of the two or if moving the grill foward was the fix but no more whistle here ...drove me crazy
  9. Mar 20, 2019 at 11:24 AM
    toyo522
    toyo522 Lost
    Nick
    LandNav
    12 Prerunner DCSB
    Not Much
    Just noticed this issue last week while driving from Houston to Ohio drove me crazy. I have 190,000 miles on my 2012 weird I’m just now getting this issue.
