High Pitched Engine Noise
Discussion in '1st Gen. Tacomas (1995-2004)' started by clarsen123, Nov 5, 2008.
  1. Nov 5, 2008 at 10:53 AM
    clarsen123
    clarsen123 [OP] New Member
    SF Bay Area
    99 Prerunner
    bed liner, nerf bars, stereo
    My engine constantly makes a high-pitched turbo-like whine like it's revving too high, but the RPM's are OK. I replaced the air filter and it helped a little. I need this truck to last a lot longer. Any suggestions? The noise is directly proportional to the RPM, and it runs fine with decent acceleration for a 4 cyl.
  2. Nov 8, 2008 at 12:19 PM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    Are you sure it's the engine? My truck is manual and is very high pitched in 1st gear with high rpms and I'm pretty sure it is just the transmission making the noise. If your truck is manual it may be the same thing.
  3. Nov 9, 2008 at 3:33 AM
    Mr.Fahrenheit
    Mr.Fahrenheit Dennis = sinneD
    American Canyon, California
    01 Taco 3.4L 5spd TRD
    K&N CAI, HUSKY LINERS, LOW PRO TOOL BOX, GRAY WIRE MOD, OPTIMA RED TOP, GOODRIDGE STEEL BRAKE LINES, FAB TECH LIFT,
    have another person rev the engine while you stick your head in the engine compartment to pinpoint the noise, you can even remove the serp belt/s to eliminate any accessory pulleys....
  4. Nov 9, 2008 at 4:55 AM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    How many miles? Might be looking at a water pump with bearings that have had enough. My Ranger made a high pitched metallic sound that changed with RPM just before the weep hole in the water pump started peeing. I couldn't tell the bearings were going out by trying to wiggle the fan until I took the belt off.
  5. Nov 9, 2008 at 4:39 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    Possibly the fan clutch?
