High pitched noise driver side, engine bay
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ak727, Sep 8, 2025 at 12:52 PM.
  1. Sep 8, 2025 at 12:52 PM
    Ak727
    Ak727 [OP] New Member
    2014 V6 Tacoma TRD Sport
    I have a high pitched noise coming from the driver side of the engine bay. I’m writing to see if anyone has ideas or past experience regarding a potential source. The noise is typically heard in park or neutral after the engine is up to temperature. The noise stops when I shift into drive or reverse, and starts up once I’m moving again and coasting around. I recently took it in for diagnostics but the sound could not be reproduced. I also just replaced the belt and idler pulleys with no apparent change. I’d appreciate any insight here. Thanks
  2. Sep 9, 2025 at 1:38 AM
    MA_TACO
    MA_TACO Well-Known Member
    Wesley Chapel, FL
    From my experience a high pitch whine like that means your alternator is starting to fail. Have it tested.
