High Pitched Noise Drivers Side 2011 Tacoma Prerunner
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2011TTDC, Dec 9, 2020.
  1. Dec 9, 2020 at 6:36 AM
    2011TTDC
    2011TTDC [OP] New Member
    2011 Tacoma Prerunner Double Cab
    Have a high pitch noise coming from the drivers side, most likely outside as I've taken it to 3 mechanics.. They don't believe it's inside and also can't figure it out. It's not the radio either, had that looked also as well as taking the driver side door off. It's driving me crazy.
    Happens when going over 45mph and gets irritating when on the highway over a period of time 50+mph. It does not happen in idle. I am wondering if it's wind dependent. Also happens when going up and down dips on the road, regardless if I'm accelerating or not. Nothing over bumps though. Any idea what it could be? I've tried looking for missing bolts or loose ones. Any guesses would be greatly appreciated.. Or if anyone has had a similar sound please chime in.
    https://vimeo.com/488949287
  2. Dec 9, 2020 at 7:59 AM
    steelcity2
    steelcity2 Well-Known Member
    Pittsburgh Pa
    2013 MGM DCSB TRD sport
    Bilsteins 5100's all 4 corners 1 inch rear spacer
    Any after market accessories, light bars, ditch lights , flags, cb antenna, roof rack..... I've seen these things make weird wind noises. How about when this noise happens reach over and pull the door inwards without wrecking, maybe the doors out of adjustment. Missing any weather striping ?
  3. Dec 9, 2020 at 8:40 AM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    '08 PreRunner here...
    Honestly, I'm having trouble hearing the noise from your vid.
    But if the conditions that you described, my first thought was trim/seal surrounding the windshield. Try using some painters tape and tape around the windshield like what they do when a windshield is replaced. See if it makes a difference.
  4. Dec 9, 2020 at 8:52 AM
    tonykarter
    tonykarter Crappie Savant
    Snuff Gully, Texas
    2018 DCSB 4x4 Sport 1993 4Runner SR5 4x4, 411,000 miles
    Pine tree air freshener
    Does it happen when you drive backwards?
  5. Dec 9, 2020 at 8:55 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    If she's hitting 45 in reverse... :burnrubber:
    wilcam47, SUMOTNK and SR-71A like this.
  6. Dec 9, 2020 at 8:57 AM
    tonykarter
    Snuff Gully, Texas
    If not then we have narrowed down the possible causes by 50%. Has anyone else on here already narrowed down the causes by 50% yet? OKAY then! I'm making progress here...
  7. Dec 9, 2020 at 8:59 AM
    memario1214
    Colton
    Missoula, MT
    :rofl:
    From her OP it would seem speed related:
  8. Dec 9, 2020 at 9:02 AM
    SUMOTNK
    Eddie
    I would think wind/speed dependant or loud vacuum leak underhood?
  9. Dec 9, 2020 at 9:03 AM
    steelcity2
    Pittsburgh Pa
    Tony, ur making progress!!
  10. Dec 9, 2020 at 9:06 AM
    tonykarter
    Snuff Gully, Texas
    Or it could be an empty beer can in the bed circulating around in the wind vortex back there. I once paid $300 to have my outboard wheel bearings replaced because I just KNEW that they were going out. I could HEAR IT. Afterall, I worked at Motion Industries and I sold bearings for a living. By God, I KNEW what a bad bearing sounded like! I left the shop and got on the highway and there it was again. Was a empty beer can blowing in circles, ticking the ridges in the bed all along...
    Or it could be that Elizabeth Warren sticker pealing up and whistling in the wind...
    deanosaurus likes this.
  11. Dec 9, 2020 at 9:25 AM
    N22WLZ
    N22WLZ Member
    2021 SR V6 AC
    I bought an 08 Prerunner a few months ago with the same thing going on. I found a generic replacement carrier bearing had been put on it so gave it a shot of motorcycle chain to see if it effected it. That was it and after replacing the carrier bearing with an OEM Dana its silent. BTW there seems to be a different part number for the Prerunners VS the 4WD replacement carrier bearings although they all use the same U-Joints.
  12. Dec 9, 2020 at 5:06 PM
    tonykarter
    Snuff Gully, Texas
    Listen, in all seriousness, a good shop will have vibration/sound locating equipment. They can put several sensors on your car, connect them to the unit and hunt it down pretty quick. Let's just hope they have someone trained to use it effectively and with extensive experience in that kind of thing...the problem is...there ain't a whole buncha money to be made in finding and fixing your noise. THAT'S the problem.
  13. Dec 10, 2020 at 5:28 PM
    HaydenS
    HaydenS New Member
    I can't open the video but...
    Does it sound like the noise is coming from the driver's side door near the top of the door? If so I had this happen to me but I was driving around 80mph in high winds. It sounds like a whistle. It could be similar to that. I would make sure the weather sealing is still good and the door is in proper work order such as dents around the edge of the door. Also, check if the door is closing all the way. Hope this helps.
  14. Dec 11, 2020 at 8:40 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Shortly after getting my motorcycle restored and road worthy. I would have high pitched whine when riding double with my wife. The whine was non-existent riding single. I spent many hours searching the bike for the source. Never could isolate it and LOML wouldn't burn time riding while I was trying to isolate the problem
    Then one day, we were out just riding, the whine was really beginning to irritate me. I stopped at a stop sign, left a little abruptly, because of the annoying sound, the front wheel left the pavement a few inches......the whine stopped. COOL. :cool::cool: I turned my head to speak to LOML.....well....she was sitting at the intersection. :eek: It was tough to go back, cause I knew the noise that would ensue, but I had to go back. :annoyed: Oh, my, the noise reached a new level on the way home. It didn't stop.
    Now, she won't ride with me. :cool::cool::cool::cool: The noise hasn't returned.
    Soylent Green2012 likes this.
  15. Dec 11, 2020 at 9:06 AM
    Soylent Green2012
    Soylent Green2012 RestoRides MotorSports
    jake
    Apopka, Florida
    2012 Tacoma Pre runner SR5 V6 Limited Edition
    chrome bull bar, 20" vision wheels, LED lighting, Custom grill.
    How about the tab on the brake pads signaling time to replace.
  16. Aug 16, 2022 at 11:38 AM
    Territhetacoma
    Territhetacoma New Member
    Meghan
    2015 Tacoma TRD
    Hi did you ever get this problem solved? My 2015 Tacoma is doing the exact same thing. It’s driving me nuts!
