High pitched sound when starting vehicle in the morning?
Discussion in 'Technical Chat' started by Atron22, Jan 22, 2010.
  1. Jan 22, 2010 at 6:22 AM
    Atron22
    Atron22 [OP] Well-Known Member
    San Felipe Peublo, New Mexico
    05 Taco Double Cab 4x4
    K&N Cold Air intake 77 Series, 3 inch leveling kit front, AAL w 1 1/2 inch block, rear Pro Comp ES9000 Shocks, Dynomax Catback Exhuast.
    I was wondering if anyone has had this before. When I start my Taco up in the morning, I get a high pitched screaching sound comeing from somewhere in the engine area. What is causing it?
  2. Jan 22, 2010 at 6:25 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    belts...
  3. Jan 22, 2010 at 6:43 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Make sure the belt tensioner is working properly.
    Inspect the belt & pulleys, make sure they're clean (don't spray anything on them).
    Then - take the belt off and inspect the pulleys for bad bearings.
    A squeek can be caused by a belt slipping (not tight enough) or a bearing going bad - a dry squeel and after they warm up, the lubrication inside the bearing flows to quiet them down.
