High pitched whine between 35-40ish mph
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cowfootball, May 16, 2023.
  1. May 16, 2023 at 3:10 PM
    cowfootball
    cowfootball [OP] Well-Known Member
    South Lake Tahoe, CA
    2022 TRD OR
    https://www.youtube.com/shorts/4eZ0WxGyTdQ
    This happens whether the truck is under acceleration, no input or braking but only when the speed is between 35-40ish mph. It doesn't matter what the engine RPM are (i.e., same speed different gear still has the sound).
    It's definitely coming from the front and it's worse on the driver side than the passenger. I've confirmed it isn't rear diff as it's inaudible when the rear window is open.
    I thought it might be a loose bolt but I went through and tightened everything up on the suspension.
    Ideas?
  2. May 16, 2023 at 5:35 PM
    jdjones
    jdjones Well-Known Member
    2022 TRD Off-Road DCSB
    Maybe the driver’s side mirror.
  3. May 16, 2023 at 6:00 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    Do you have a cat stuck somewhere under the hood?
  4. May 16, 2023 at 6:23 PM
    Ehahn84
    Ehahn84 Well-Known Member
    Oly, WA
    2021 DCLB TRD Off-Road MGM
    OTT. DD SS3. RLD Canopy. Yokohama G015.
    It's your defrost vent. Turn off any mode of defrost and see if it goes away or ceases to happen.
  5. Jul 6, 2023 at 5:51 PM
    cowfootball
    2022 TRD OR
    I finally got back around to troubleshooting this: not the defrost vent, not the drivers side mirror.
    It's also only audible when the windows are down, so it's definitely coming from the front-end somewhere. I thought it might be the body line whistling where it was cut and lines up against the bumper so I taped up every join on every body panel and the bumper but the whine is still audible. Pulled the skid plates, torqued all the front-end, no change. Sat in neutral and revved it up to 2500 rpm or so and no sound.
    It's audible moreso on the left than the right which is making me think some kind of suspension component.
    Idler pulley is my next stop, I guess.
  6. Jul 6, 2023 at 6:05 PM
    mtip
    mtip Go Outside & Play!!!
    South Louisiana
    18 TRD Sport 6MT 00 Tundra 5MT
    You sure you're not being pranked?
    Good luck, I hope you find the source
  7. Jul 6, 2023 at 7:14 PM
    Phlogiston
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    That sounds like feedback, like the ring of a mic about to takeoff.
  8. Jul 6, 2023 at 7:42 PM
    cowfootball
    2022 TRD OR
    Hah I considered this. Maybe not exactly this but a zip tie or label or something near the intake.
    but alas…
  9. Jul 7, 2023 at 4:46 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Thats as bad as one of our guys putting a hunk of cheese on the heater core of a friends older chevy truck during one winter.
    Phlogiston likes this.
  10. Jul 7, 2023 at 5:49 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    :rofl::rofl:
    I hope at least it was Limburger
  11. Jul 8, 2023 at 12:49 PM
    cowfootball
    2022 TRD OR
    So... it was not this. But it was kind of this.
    This is the inside of a harmonica:
    These are my ditch lights:
    Spot the difference.
    (It was my drivers side ditch light. It was at an extremely specific angle that caused the whine. A degree in either direction and the sound is gone. I can't even get it back in the spot that reproduced it.)
    mtip[QUOTED] likes this.
  12. Jul 8, 2023 at 4:12 PM
    zoo truck
    None
    It was some name in the blue cheese family. This guy drove a few miles before blowing his lunch. Same guy another time, we mixed cayenne pepper in his red man chewing tobacco.
