High Pressure Fuel Pump Chirping Noise
Discussion in '3rd Gen. Tacomas (2016-2023)' started by radio_dave, May 7, 2024.
  1. May 7, 2024 at 11:22 AM
    radio_dave
    radio_dave [OP] Member
    Dave
    2016 Tacoma SR5
    My wife noticed an engine tick two days ago after starting the Engine. Even with new hearing aids, I couldn't hear it. So I took it to my mechanic today and he diagnosed it to the high pressure fuel pump.
    He then pulled up a service bulletin on his computer, T-SB-0016-18 and printed it out for me and told me to call Toyota to see about a free replacement.
    I did, if the issue is the fuel pump, they are going to replace it for free. If it's not the fuel pump, I'm out $148 diagnostic fee.
    If it is the pump, and they replace it for free, I think I'll give the $148 to my mechanic!
    Just wanted to give everyone a head's up on a non-recall, no-warranty free repair from Toyota.
  2. May 7, 2024 at 11:35 AM
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    yep its active 10years from the day you purchased your tacoma, also is your mechanic going to change it for free? just go with toyota
  3. May 7, 2024 at 11:46 AM
    Southwest Tacoma
    Southwest Tacoma Well-Known Member
    Southwest
    2020 Super White SR DCSB
    You should be able to pull up your VIN and see if your vehicle has an active recall on it.
  4. May 7, 2024 at 2:28 PM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    Think you have a honest mechanic. A rare find now a days . Hold on to bulletin and take it to Toyota when it gets worse. Good luck
  5. May 7, 2024 at 7:09 PM
    Freetime
    Freetime Well-Known Member
    2016 TRD OR AC 4x4 Quicksand
    The new one is going to do it too. They all do, especially if you use ethanol gas.
  6. May 7, 2024 at 7:25 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    You make a bold statement. Can you back it up?
  7. May 7, 2024 at 8:20 PM
    Freetime
    This problem has existed with the HPFP from way back in 2012 in the FRS and other cars in their lineup. My 2016 tacoma started doing it within 6 months. A lot of people will mix an occasional tank of non-ethanol fuel in to lubricate the pump.
  8. May 7, 2024 at 8:22 PM
    gudujarlson
    Minnesota
    We have a different definition of scientific evidence.
  9. May 7, 2024 at 8:27 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    :alien: Take me to your dealer :rasta:
    Blak Shinobi likes this.
  10. May 8, 2024 at 8:20 AM
    Schultz0462
    Schultz0462 Well-Known Member
    Memphis, TN
    2017 Tacoma 4x4
    Just had mine replaced also. 2017 SR 4X4 with 120,xxx miles. Dealer replaced every pulley I had trying to diagnose, even with me telling them about the TSB on the HPFP.
    shakerhood likes this.
  11. May 8, 2024 at 9:09 AM
    radio_dave
    Dave
    2016 Tacoma SR5
    In lieu of scientific evidence, even though we're all scientists in our own way here, how about I quote the last line of the service bulletin repair procedure? Step 4 of T-SB-0016-18 (after the repair is completed) states,
    "Confirm that the chirping noise is reduced."
    The inference I get from step 4 is that there will still be a chirping noise, just harder to hear.
    Thanks all.
  12. May 9, 2024 at 3:18 PM
    ToyodaSun
    ToyodaSun Well-Known Member
    Parts Unknown
    17' DCLB TRD OR
    My taco is not my daily and it is tuned so it gets ethanol free fuel. After many thousands of miles of testing and travel across the country I can confirm that there is no chirp with ethanol free fuel. But when I'm on the road and the corn-syrup has to hit the tank boy does she start chirping a symphony.
    Most of us should be covered with the HPFP extended warranty due to fuel leak so if we ever need a replacement hopefully the new pumps aren't atrociously loud. I've never had a vehicle that's exhibited this characteristic. Taco is great otherwise.
  13. May 9, 2024 at 7:29 PM
    Sct60
    Sct60 Member
    Scott
    2018 White Tacoma TRD
    None yet
    While driving below 60 mph I notice a slight hesitation almost sputtering slightly not sure if anyone else feels this. Doesn’t do it at higher speeds than 50+ or lower speed lower than 40? Any suggestions?
  14. May 10, 2024 at 3:39 AM
    ToyodaSun
    Parts Unknown
    17' DCLB TRD OR
    Torque converter shudder. Well known issue on a lot of toyotas. They lock the torque converter around 1500 RPM to save more fuel.
    Got this problem on my 3rd gen tacoma and on a 6th gen camry I daily. The lady's 7th gen camry does not have this problem. I just deal with it by driving in sport mode all the time and keeping the RPM where I want it. These transmissions are stout and they work well with directed shifting.
    I don't mind it but can understand how it would this would be an annoyance to most people.
  15. May 10, 2024 at 6:10 AM
    Sct60
    Sct60 Member
    Scott
    None yet
    Thanks for info, S+?
  16. May 10, 2024 at 6:17 AM
    ToyodaSun
    Parts Unknown
    17' DCLB TRD OR
    S-mode or S-mode and ECT mode at the same time. Experiment with it to find your sweet spot. Occasionally I use both at the same time when I need to hold gears longer for the extra giddy-up.
  17. May 10, 2024 at 8:26 AM
    Sct60
    Sct60 Member
    Scott
    None yet
    Thanks man!
  18. May 10, 2024 at 8:43 AM
    Mike Z
    Mike Z Well-Known Member
    Where do you buy ethanol free gas?
  19. May 10, 2024 at 10:08 AM
    ToyodaSun
    Parts Unknown
    17' DCLB TRD OR
    Check out an app called pure gas and it will show you stations that have ethanol free. I'd find the most reputable station franchise in your area that carries it and go there.
  20. May 10, 2024 at 5:32 PM
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Falken Rubitrek AT 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    I use ethanol blend all the time. Hard to find gas without it, but I haven’t looked. Just need to buy the regular cheap gas nothing special needed. My truck runs just fine. Haven’t heard these chips going on 91K.
