High pressure fuel pump noise
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 16'TaCoMa6MT, Mar 4, 2017.
  1. Mar 4, 2017 at 8:10 AM
    16'TaCoMa6MT
    16'TaCoMa6MT [OP] Member
    2016 Tacoma TRD 6MT inferno
    I've got 34500kms on my Tacoma, it always had a slight hissing coming from tank area, thought it was normal, could still very well be but since about 28000kms it's been ticking louder at idle on passenger side, I brought it for second oil change at the dealer and told them about it, they told me it was the high pressure fuel pump and they will replace it, they said they've never seen, or done it before which to me is a lil scary lol first oil change I got by them I added a quart of oil when I heard ticking at idle the next day while out of town hunting and I hate that I can't bring it in myself or trust them to let someone who knows how to drive standard, when he took it into the parking lot after the oil change he shifted into 2nd without letting off the gass and not being gentle with the clutch made a couple loud caclunks man oh man, anyways my question really is who has had this problem and what is actually the issue? The pump simply failing making noise? Over pressurizing? Sucking air? What is causing it to fail? image.jpg
  2. Mar 4, 2017 at 10:58 AM
    Freetime
    Freetime Well-Known Member
    2016 TRD OR AC 4x4 Quicksand
    The period(.) key on your keyboard is on the bottom right down below the "L" key. Learn to use it.
    Edited to appease the panty-sniffing sissies
  3. Mar 4, 2017 at 11:16 AM
    TRDinOhio
    TRDinOhio Well-Known Member
    Andrew
    Lima
    16 Trd Pro 4Runner
    No more Turd-gen :)
    I don't specifically know Toyota high pressure pumps but I'm familiar with BMW and Fords. Both use a steel return spring that breaks inside of the pump and cause unusual or loud noise. Most of the time though the pump doesn't maintain full pressure either.
    Just spitballing
  4. Mar 4, 2017 at 11:42 AM
    16'TaCoMa6MT
    Never do maintenance on my own trucks? Excuse me who the hell are you to tell me what I can and Can not do? Once my warrantee is over the only person to touch it will be me. Save your smart ass coments. I build, repair & maintain everything I own and then some. so you're saying I should of drove it approx 300km to the dealer with nothing showing on the dip stick, so he could top it off for me? Give your head a shake!
  5. Mar 4, 2017 at 11:49 AM
    16'TaCoMa6MT
    I have mostly been running it on 87 octane from Esso. like it sais to use in the manual. Might be why? Up to 10% ethanol could be The problem? Hate that shit, eats away at rubber and brass in older carbs.
  6. Mar 4, 2017 at 11:54 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I am not a fan of Ethanol either, but l think the guys on here got lucky just switching brands of fuel.
  7. Mar 4, 2017 at 1:30 PM
    Freetime
    switching brands will do nothing for you. Running an occasional tank of non-ethanol through it will lubricate the pump correctly. It's been proven in the FRS/BRZ which uses the same injection technology from Toyota and that car has been out since 2013.
    CHIRPING (CRICKET) NOISE
    http://www.ft86club.com/forums/showthread.php?t=9836
    http://www.ft86club.com/forums/showthread.php?t=12422
    http://www.ft86club.com/forums/showthread.php?t=8678
    http://www.ft86club.com/forums/showthread.php?t=9837
    http://www.ft86club.com/forums/showthread.php?t=9686
    shakerhood[QUOTED] likes this.
  8. Mar 4, 2017 at 1:34 PM
    2017OR
    2017OR Well-Known Member
    2017 TRD Off-Road
    TRD exhaust, Pro Grill, Access Tonneau cover, TRD Pro wheels, BumperShellz, Pro shift know, Yota LED grille lights
    rude
    16'TaCoMa6MT[OP] likes this.
  9. Mar 4, 2017 at 1:38 PM
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    Just filled up with non ethanol gas the other day and so far the pump has been quite.
  10. Mar 4, 2017 at 1:39 PM
    Freetime
    Awesome Avatar. Billy and the Boingers will return and I'm ready.
    elduder[QUOTED] likes this.
  11. Mar 4, 2017 at 3:20 PM
    16'TaCoMa6MT
    Why would they give a 3cent per litre esso gas card at ur first service and specifically say to run on 87 octane in the manual if it does contain ethanol and because of that doesn't lubricate the fuel pump like it should? Something needs to be redesigned or specified. Other than the engine not gaining my trust too quickly I've been enjoying the truck it's self so far. Diesel swap when that 3.5 takes a shit, if it's off warrantee lol
  12. Mar 5, 2017 at 11:33 AM
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    I noticed this slightly yesterday. Been running 10% ethanol since new. Now at 5K miles. Anyone use a fuel additive meant to increase lubricity? Marvel mystery oil or the like?
  13. Mar 5, 2017 at 11:47 AM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Nice Sno-Jet man... is that a 1968???? :thumbsup::canada:
  14. Mar 5, 2017 at 2:55 PM
    16'TaCoMa6MT
    Thanks, had it 10 years, restored it in highschool, it's a 1970 star jet 292
  15. Mar 5, 2017 at 8:36 PM
    JETACO
    JETACO New Member
    Austin, TX
    2017 OR
    The high pressure fuel pump is located on the passenger side of the engine. The low pressure pump is in the fuel tank. Maybe it's the low pressure relief valve in the fuel tank, although the fuel tank is closer to driver's side?? Or maybe something malfunctioning with the EVAP canister pump/system? That seems more likely if you're hearing a hissing.
    By the way, first post, bought a 2017 OR in November. Best tens of thousands of dollars I've ever spent!
