High revs on start up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by toyboy, Mar 11, 2012.
  1. Mar 11, 2012 at 3:24 PM
    toyboy
    toyboy [OP] Member
    George
    Brampton, Ontario
    05 SR5
    Hi everyone, I bought my first ever Toyota and have been driving it now for two and a half months. It's a 2005 Tacoma Access cab 4X2 4cyl that I bought from a co-worker that retuired. I use it for my job as furnace technician.
    I have a couple of questions about it. 1. I notice that it revs really high when i start it in the morning. Is this normal? It revs upto 200+ RPM and stays there for a while. Now i've driven a lot of different vehicles but for the last 13 years it's been Ford products. In addition to the Tacoma I own a 2000 Ford Excursion Diesel. I know my diesel is designed to kick up the revs after start up to maintain the proper pressure for the fuel pump, but it only goes up to 1000-1300 RPM. Is there a reasoin why the Tacoma revs so high? If this isn't normal how can i adjust it?
    This leads me to my second question. How many KM (miles) do these trucks get to a tank of fuel. For 65 liters of fuel I get about 500Km give or take. Is this normal? Does the high rev on start up have any bearing on this?
    Thanks,
    GD
  2. Mar 11, 2012 at 3:28 PM
    08bluetacoma
    08bluetacoma Well-Known Member
    Dave
    Ontario, Canada
    07 SR5 Rad Red
    6 inch fabtech alpine stereo flowmaster exhaust
    yah mine revs high when its cold out as for 500km per tank thats about what i get maybe a little less cause of bigger tires but everything sounds normal
  3. Mar 11, 2012 at 3:33 PM
    Syncros
    Syncros Well-Known Member
    That fuel consumption seems high to me, I get 540km to 65L with a V6/4wd/Auto. 480km if I drive in the city/short trips only.
  4. Mar 11, 2012 at 3:41 PM
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    Extra fog lights behind grill, Pro Form rubberized undercoat, Fog lights on w/ high beams mod, Lighted 4wd switch, Husky Liners, 12v always on, Yellow wire mod, DEVIL HORNS BABY!! OME 886's Nitrochargers w/ 1.5" AAL with 1" lift block, Redline hood struts, front/rear winch wiring, Blue Sea systems Fuse Block, Spidertrax spacers, Wet Okle seat covers, ECGS front diff Bering Replacement Are LR UCA's right for me???
    You get HUNDREDS of km's per tank?! How?
    And my V6 revs to 2000+ at startup, and hangs there for a while
  5. Mar 11, 2012 at 3:42 PM
    kite
    kite Well-Known Member
    Squamish, BC
    Red Truck
    The revs are normal. They drop pretty quickly and I doubt that has much of an effect on your mileage.
    Mileage seems a little low for a 5 lug.
  6. Mar 11, 2012 at 6:31 PM
    Utard
    Utard Well-Known Member
    Mark
    Nyssa, Oregon
    2012 DC LB 4WD TRD SPORT NAVI
    ------------------------------------------------------------ Stabilus.EZDown.Tailgate http://www.ezdown.com/home.php ----------------------------------------------- Tekonsha.Primus.IQ.Trailer.brake http://www.tekonsha.com/content/default.aspx---------------------------------------------------------------- Leer 180 CC http://www.leer.com/Truck-Caps#------------------------------------------------ Firestone Air Rite Air Bags--------------------------------------Kargomaster Rack
    I think the high revs is the ECU trying to warm up the cats quicker for better emissions?
  7. Mar 11, 2012 at 6:31 PM
    kite
    Squamish, BC
    Red Truck
    Bingo.
  8. Mar 11, 2012 at 6:36 PM
    ScreamingTaco
    ScreamingTaco Huge Member
    2012 TRD Off-Road AC
    Goodyear Duratracs, TRD cat-back exhaust, bed tool box, bed extender.
    Increased RPM is normal until the engine reaches operating temperature.
  9. Mar 11, 2012 at 6:43 PM
    joes06tacoma
    Joe
    Central Coast, CA
