High RPM/Bad gas milage 'normal'?
Discussion in '4 Cylinder' started by hats009, Dec 11, 2011.
  1. Dec 11, 2011 at 2:05 PM
    hats009
    hats009 [OP] Well-Known Member
    09 4x4 TACOMA TRD
    I am thinking that I committed gas mileage suicide when I installed a new set of 32" TOYO Open Country M/Ts from the bald highway tread 31" tires I had on.
    I am also going to be putting a canopy on in a couple of weeks which I am now dreading because of the added weight.
    While I am on the highway the RPM bounces around quite a bit and seems extremely sensitive. While I am driving 65-70 it likes to stay between 2300-2500 and sometimes it stays in low 3000's and won't go back down unless I take my foot completely off the pedal and slowly push back down.
    Is this just a 4 cylinder characteristic?
    And fuck, going up hills sucks of course. If I were to keep it in low RPM range i'd be going 30mph.
    I have been wanting to change the header and exhaust for shits and giggles. and... I was planning on ordering off road bumpers.. which would ultimately weigh the truck down more, correct? but they look so wicked.
    I have been reading about "Regearing"? I am not quite sure how that works - is it worth it, and how costly is it, and is that related to what I am talking about?
    thanks for any input, you all are awesome and I love this place. :D
  2. Dec 11, 2011 at 2:09 PM
    slmgt
    slmgt Well-Known Member
    Greater Seattle Area
    11 TRD Sport w/ JBL DCLB V6 AT
    Husky floor mats (Fr and Rr)
    Higher RPMs certainly aren't helping your situation. Try using Cruise Control if you have it.
    What kind of mileage are you getting? And is it mostly City or Highway?
  3. Dec 11, 2011 at 2:12 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Your truck is downshifting on hills to get the engine in the power, which just so happens to be at a high RPM.
    The fix is to regear the differentials to a lower gear ratio, making the engine not have to work as hard to push the truck.
    Look into east coast gear supply for regearing options. I would recommend going to 4.56:1 at least or if you don't do much highway driving, 4.88:1.
    Just fair warning, its going to be expensive.
  4. Dec 11, 2011 at 2:41 PM
    hats009
    09 4x4 TACOMA TRD
    I am getting 15.5 - 18 mpg these past few weeks. Super bummer. And I don't really gun it either. I do about 50/50 highway and city when I am home but I have been doing mostly highway trips getting 17ish mpg.. or 240-250 miles per tank.
    I do have cruise control, BUT, the cruise control jumps around RPM more than without it, making it seem useless to me. I may be wrong.
    4.56:1 huh? Is it worth it?
  5. Dec 11, 2011 at 2:51 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I went to 4.88 to regear back for performance from my heavy 285/70r17 MTR kevlars.
    Regained a little spunk, but no mpgs.
    16.5 city highway commute, fully corrected.
  6. Dec 11, 2011 at 9:36 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Honestly if you're that worried about MPG I would go down in tire size. With that 4 cylinder paired with an automatic transmission the truck will be slow and get bad mileage with bigger tires.
    If you want to run big tires and get decent mileage, you pretty much need a v6. I was getting 18 with my old 33" tires.
  7. Dec 12, 2011 at 5:59 AM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    re-gear is so worth it (4.56's) plan on spending about $1700.00 said and done (if your having a shop install it)
  8. Dec 12, 2011 at 8:15 AM
    speedydave
    speedydave Well-Known Member
    Dave
    Hickory, Nc
    Mustang GT
    You are probably getting better than that if you haven't factored in that the speedo/odometer is way off with the larger tires.
    But, big tires ruin gas mileage. There's not much you can do about it.
  9. Dec 12, 2011 at 9:56 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    32's put the speedo dead on generally.
    They normally read fast with the stock 31's.
  10. Dec 12, 2011 at 10:00 AM
    magic
    magic Well-Known Member
    bud.... get a 3.4L :)
  11. Dec 12, 2011 at 10:01 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I have a V6 but did not notice much of a difference with the addition of a shell. On the highway, the added weight is offset by improved aerodynamics, in the city you might be a little worse because you're accelerating with more weight. Plate bumpers will not help your cause. They look cool but they are generally heavy. Some manufacturers make aluminum versions that weight very little. Typically the idea is to add plate steel for protection, just just for looks... If you're really concerned about MPG's, I wouldn't be considering plate bumpers unless you need the protection.
