High rpm going uphill road highway.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Makanahi, May 3, 2025.
  1. May 3, 2025 at 3:32 PM
    Makanahi
    Makanahi [OP] Member
    Mark
    07 tacoma prerunner 4.0 V6
    Stock
    My buddy owns a 2018 toyota trd sport 3.5 V6 w/ 3" body lift with extra wide rims & tires. I believe his tires maybe 33". He says driving uphill 3/4 ways high incline ways his rpm reaches 3000+ rpm almost 4000 just to get @ 55 mph. High reving very loud. Is this normal?
    I own a 2007 V6 4.0 toyota tacoma sr5 prerunner same route alittle over 2000 rpm & my 2004 V6 4.0 toyota 4runner sport limited edition is lower very much smoother & softer. both of my toyota's are stock. Is this because of the gear ratio or lifting & adding bigger rims, tires affect going uphill compared to leaving it stock?
  2. May 3, 2025 at 3:36 PM
    TS4x4
    TS4x4 Well-Known Member
    2018 TRD Offroad
    To put it in perspective, that lift & tire combo is the same as if you tried running up a hill with an extra 50lbs of weight tied to each leg. You’d be huffin’ and puffin’ too lol.
    Kolohe07, Chew, RustyGreen and 4 others like this.
  3. May 3, 2025 at 3:39 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Well yeah you’re going uphill, it takes that much more energy and effort to get larger tires to roll up a grade.
    Chew and Makanahi[OP] like this.
  4. May 3, 2025 at 3:43 PM
    yotadust
    yotadust Well-Known Member
    Yes, what you're describing is normal for a lifted truck with oversized tires—like your buddy’s 2018 Tacoma TRD Sport running 35" tires and a 3" lift.
    Here’s why:
    1. Larger Tires Change the Effective Gear Ratio
    • Bigger tires (like 35s) reduce the effective axle gear ratio, making the engine work harder to turn them.
    • This causes the truck to lose torque at the wheels, especially noticeable during uphill driving.
    • To compensate, the transmission downshifts more often and the engine revs higher to maintain speed or power.
    ⚙️ 2. Stock vs Modified Gear Ratios
    • Your 2007 Tacoma and 2004 4Runner are stock with factory-matched gearing and tire size, so the RPM stays lower and the engine feels smoother.
    • Your buddy’s truck probably still has the stock differential gears (e.g., 3.91 or 4.30), which are not ideal for 35" tires.
    • For 35s, a proper regear (like 4.88 or 5.29) would bring the RPMs back down to stock-like behavior and improve performance.
    3. Weight and Rolling Resistance
    • The lift and wider tires add rotational mass and aerodynamic drag.
    • These also stress the transmission and engine more on inclines, forcing them to rev higher.
    Summary:
    Yes, your buddy’s higher RPM (3000–4000) on steep climbs is expected due to:
    • Larger/heavier tires
    • Body lift (added drag)
    • Likely no re-gearing
    • Transmission downshifting to compensate
    If he wants to improve drivability, fuel economy, and engine wear, re-gearing the differentials to match the 35” tires is the right move.
    what do you think?
  5. May 3, 2025 at 4:59 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    My 2006 TRD OR had the 4.0V6 - my current TRD OR has the 3.5V6.
    The 4.0 had better torque at lower RPMs - I could start from a stop in 2nd gear. The 3.5's power band is at higher RPMs and consequently climbing hills it has to rev higher. This is normal as the 2 engines are vastly different when it come to torque & horsepower. Add to that the tuning that satisfies the EPA requirements. Changing to larger diameter tires on a 3.5V6 really highlights the difference in power band and it shows in the RPM range that works best for the 3.5.
    TS4x4 likes this.
  6. May 3, 2025 at 5:05 PM
    Makanahi
    Mark
    Stock
    yotadust likes this.
  7. May 3, 2025 at 5:06 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    Tell him to try in ECT mode if he is not doing that. may make a difference?
    Makanahi[OP] likes this.
  8. May 3, 2025 at 5:09 PM
    Clearwater Bill
    Billy
    Largo Florida
    The good news is some think it looks good. :D
    Chew and Canadian Caber like this.
  9. May 3, 2025 at 5:12 PM
    Makanahi
    Mark
    Stock
    @CtYankee
    I was very disappointed that the 2016-23 tacoma's got 3.5L V6. & the oil filters now below under the engine. I love the exterior design on them. I totally hate those new design tacoma's 2024-25.
    whoareyou133 likes this.
  10. May 3, 2025 at 6:50 PM
    eurowner
    eurowner Duke Sky
    Scoty
    It’s not Friday.
    Chew and TS4x4 like this.
  11. May 3, 2025 at 7:07 PM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    It's got a piano tied to it's ass. Normal with all crap attached to it.
    Chew likes this.
  12. May 5, 2025 at 3:39 PM
    Makanahi
    Mark
    Stock
    @yotadust
    My buddy is claiming that when he bought his brand new 2018 tacoma stock. Going up the same hill 3/4 ways that is much steeper part was doing the same thing even at stock. Reving @ 3,000 to 4,000 rpm.
  13. May 5, 2025 at 3:50 PM
    Clearwater Bill
    Billy
    Largo Florida
    And in my 20's I was mistaken for Brad Pitt as Joe Black. I did have blond hair.
    So, yes, it revved stock. Just like I had blond hair. No, it didn't work as hard as it does now
    and I still don't favor Brad.
  14. May 5, 2025 at 3:56 PM
    bryannn
    bryannn Active Member
    Your buddy should probably look into get a tune also if he's running 33s. I will say that helped me substantially on climbing steep highway hills and maintaing speed with steady rpms. I went with an OTT and have been very happy with the results. It made a noticeable difference on my daily highway drive where I am going up a grade every day.
  15. May 5, 2025 at 3:57 PM
    BigTang
    BigTang Well-Known Member
    C
    2022 SR
    On a hill 5/8 maybe 9/16 mine will hold 3rd gear like its going to pop trying to maintain 65mph.
  16. May 5, 2025 at 4:07 PM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    what about using S mode to self shift?
    Just keep it in the gear that seems the best for going up the hill.
    I have a hill here and when i go up it i always use S mode and lock it in 3rd
    then when i get to the top just bump it back to D
  17. May 5, 2025 at 6:39 PM
    CT Yankee
    CT
    That's the ideal power range is for the 3.5V6.
