High RPM on highway
Discussion in '3rd Gen. Tacomas (2016-2023)' started by beatnik, Jul 10, 2023.
  1. Jul 10, 2023 at 1:26 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    All engine builders will tell you rpm is rpm, and hardest on valve train components. There is no such thing as a sweet spot when it comes to higher rpm, and engine life.
    Btw, my tires are well under 40 lbs, not the 55 lbs you mention.
  2. Jul 10, 2023 at 2:05 PM
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    I guess I think of sweet spot in terms of relative performance (like specific fuel consumption).
    And sorry, the tire comments were meant for the OP.
  3. Jul 10, 2023 at 7:04 PM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    If you're ever down there you'll feel the difference
    cryptolime likes this.
  4. Jul 10, 2023 at 8:41 PM
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
    What tune do you have?
  5. Jul 10, 2023 at 11:26 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    2
    Where? Seattle or Montana?
  6. Jul 11, 2023 at 1:19 AM
    51Beets
    51Beets Well-Known Member
    2020 TRD Offroad
    Too much to list
    This is the worst part about the truck. I got mine tuned to help, and it does, marginally.
    I live in central Ohio, we are pretty flat here with more rolling hills than anything but if I use cruise control at all, I'm hovering at 3-3300 the whole time. Adaptive cruise control is worse but both settings suck. Even when it's working "well" I have to help it along to get up slight inclines without it down shifting and shooting up to 4500+.
    It's utterly inexcusable a $45,000 mid size truck, with supposedly 250hp and tq requires shifting on a constant basis to hold any type of highway speed.
    cropduster78 likes this.
  7. Jul 11, 2023 at 4:03 AM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    It almost sounds like you have a tune on it . With slightly bigger tires and leveling kit I wouldn’t see that much jump in rpm . Did you ask the owner if they had a tune done ?
  8. Jul 11, 2023 at 4:11 AM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    I have KDMax. I highly recommend it, I’ve had it for about 2 years now and I get the newer versions installed every once in a while because I like it so much.
    wiljayhi likes this.
  9. Jul 11, 2023 at 4:18 AM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    I’m not trying to be a jerk but a tune would fix the OP’s issue, not cause it. I just don’t want want the OP to have bad info. Tunes are designed to prevent things like running at high RPMs due to the horrible factory shift points. If the truck was tuned, he probably would not have had this issue (at least not as high in the RPM band).
    Again, not trying to be an asshole! Just want accurate info out there.
    :cheers:
    TacoManOne and beatnik[OP] like this.
  10. Jul 11, 2023 at 4:27 AM
    zoo truck
    None
    I don't get the part about having to run the truck at 3k, or higher where you are, unless something is really wrong with the truck, or you like going over 80 mph all the time. It's sort of hilly here in New England. My truck rarely sees over 2500 rpm 90% of the time. Less than 2k much of the time, as my gen1 tundra did. It's got plenty enough bottom end for cruising along. It sounds to me more you're driving one of those 4 bangers.
    Believe me, if you drove my truck, you don't need a tune.
  11. Jul 11, 2023 at 5:46 AM
    Schlappesepple
    Joe
    2020 4Runner ORP
    I think all you tune and V6 complaint guys missed the fact that OP has the 2.7, i.e. 160 hp at ~4000* rpm (or wherever).
    Your experiences are going to be a little different.
    * Actually at 5000 rpm
  12. Jul 11, 2023 at 5:58 AM
    zoo truck
    None
    Yeah, got a bit side tracked. Those 2.7's in these gen3 chassis should have never been offered.
    beatnik[OP] and Chew like this.
  13. Jul 11, 2023 at 9:10 AM
    Vlady
    Issy, WA
    This normal behavior of AT tranny when upshift in S . V6 does the same, even on tuned one.
    You need a lighter tires , tune and perhaps regear to stay in normal rpm range.
  14. Jul 11, 2023 at 9:20 AM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    :rofl::rofl:
  15. Jul 11, 2023 at 9:20 AM
    #35
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    I have no problem keeping up with aggressive California traffic and I haul moderate loads of 300-400 pounds while we remodel our house.
    beatnik[OP], cryptolime and LeakyAC like this.
  16. Jul 11, 2023 at 9:35 AM
    #36
    LeakyAC
    Anywhere at sea level
  17. Jul 11, 2023 at 12:01 PM
    #37
    zoo truck
    None
    Sure, if you beat the piss out of it.
  18. Jul 11, 2023 at 12:05 PM
    #38
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    I don’t consider revving the engine up to 4500 RPM as “beating the piss out of it.”
    My V6 4Runner was also pretty sluggish until it went above 4000 RPM.
    gmtech likes this.
  19. Jul 11, 2023 at 6:02 PM
    #39
    51Beets
    2020 TRD Offroad
    Too much to list
    I have a 2020 TRD Off-road. I don’t “run my truck at 3k”, the computer does. I don’t choose to have it there. I generally keep it around 73-75.
  20. Jul 11, 2023 at 6:23 PM
    #40
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Meh. What about the manual 4 cylinder Nissans and Honda sedans that run 4200 rpm at 80 mph and live to see 300K+? There’s a redline for a reason, anything below redline is safe for a very long time….
    A few more examples just because. I had a 3.0 ‘05 Ranger which had no balls. I bought it at 155K and took it to just under 210K. I can’t think of one day I drove that thing where I didn’t take it to redline. Still ran perfect when I sold it and didn’t burn a drop of oil.
    The Jeep model I own had an optional factory 3-speed automatic that when paired with 225/75R15 tires and 3.73 gears, would turn 3200 rpm at 70. Tons and tons of those made it beyond 250-300K.
    In short, if the motor is built right and oil and such is kept up with, the rpm isn’t gonna hurt a thing. That’s the whole reason you have oil, to provide a barrier that practically prevents almost all wear. On the contrary, too low of rpm all the time could definitely have bad results.
    Overall, my truck will be one example to prove me either right or wrong. The way it’s geared I am over 3000 rpm at highway speeds and I am on the largest tire size I want to run. I drive 25K miles a year. If there’s a problem from doing this, it won’t take all that long to show itself.
    SH10151 and gmtech like this.
