High RPM on highway
Discussion in '3rd Gen. Tacomas (2016-2023)' started by beatnik, Jul 10, 2023.
  1. Jul 11, 2023 at 7:14 PM
    #41
    51Beets
    51Beets Well-Known Member
    2020 TRD Offroad
    Too much to list
    Show me this... because I've never seen that happen...
    Specifically, a honda of nissian 4cyl maintaining 4k+ for much of it's life.
  2. Jul 11, 2023 at 7:16 PM
    #42
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    There are plenty of them. The modern Nissan Versa 5 speed manual runs about 3800 at 75 and 4100 at 80.
    They have no power, so they have to do that. It doesn’t kill or hurt them.
    another good example is the Miata. My cousin’s 01 5 speed is somewhere around 3750 at 70. That scales to over 4K by 80 also.
    gmtech likes this.
  3. Jul 11, 2023 at 7:22 PM
    #43
    51Beets
    2020 TRD Offroad
    Too much to list
    A "modern Versa" isnt a good example of a quality motor lol.
    I've driven plenty of "economy" cars from the 90's and early 2000's, with automatic and manual trans and not a single one lives about 3k at highway speeds. Not. a. single. one.
    Also, just for clarification, I'm not calling you a liar. I'm just saying I've not seen this personally.
  4. Jul 11, 2023 at 7:32 PM
    #44
    BLtheP
    Plano, TX
    To be fair, I gave two examples. An opinion on the Versa doesn’t change the fact that it leaves the factory turning 4k at 80 and it isn’t falling apart from it. I also listed the Miata which turns plenty of rpm as well. There are other Hondas that I could go find and post that I don’t feel like doing that for. You haven’t seen them, but I can assure you they are out there.
  5. Jul 12, 2023 at 4:56 AM
    #45
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    My brother had a 2001 highlander v6, and it ran a bit over 3k at 65 mph. He got only 110k miles out of it before the engine failed. Toyota put an extra gear in the transmission the following year to drop the engine rpm at highway speeds. Toyota had known they had an issue with those 2001's.
  6. Jul 12, 2023 at 5:21 AM
    #46
    BLtheP
    Plano, TX
    Something doesn’t add up. Highlander started in 01 and they used the same 4 speed from 01-03. The U140E.
    All that aside, there is no proof that revs are what killed that one engine.
    Canadian Caber likes this.
  7. Jul 12, 2023 at 6:39 AM
    #47
    gmtech
    gmtech Well-Known Member
    quad cities illinois
    2016 trd or. 2024 trd OR iforcemaxx!!
    Stock AF
    why dont you guys get together and call Mike Sweers and ask him if running at 3500-4krpm on highway damages these engines.. and record it so we can hear him laugh in your face.
    its pretty ignorant to think any modern engine cannot handle those rpms for long durations of time.
  8. Jul 12, 2023 at 6:40 AM
    #48
    gmtech
    Stock AF
  9. Jul 12, 2023 at 7:38 AM
    #49
    zoo truck
    None
    Anyone with a brain will tell you running high rpm for extended periods with kill an engine, or certainly shorten engine life. Even the best built nascar cup engines running at 8k are pretty well spent after just 500 miles.
  10. Jul 12, 2023 at 7:42 AM
    #50
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    Dude you can't make blanket statements like "3-4k rpm will blow up your motor". It's simply factually incorrect.
  11. Jul 12, 2023 at 7:43 AM
    #51
    LeakyAC
    Stop lol
  12. Jul 12, 2023 at 7:43 AM
    #52
    gmtech
    Stock AF
    ok. then out of the 1 million plus tacomas built since 2016 with the 3.5l engine . why isnt there thousands of people complaining about their engines that have failed? 3500-4500rpm isnt high rpm... 8k is... our trucks redline is well below that... this is a none issue..
    LeakyAC likes this.
  13. Jul 12, 2023 at 7:51 AM
    #53
    zoo truck
    None
    Didn't say it will blow up, but will shorten life. You might even notice seals leaking before their time.
  14. Jul 12, 2023 at 7:55 AM
    #54
    gmtech
    Stock AF
    nope.
  15. Jul 12, 2023 at 7:55 AM
    #55
    zoo truck
    None
    Idk, you read enough of them here on tw have for one reason, or another. All I can say is the majority of these 3.5's don't run at those rpm. Mine very rarely ever has, It's only here you guys are saying it.
  16. Jul 12, 2023 at 8:11 AM
    #56
    zoo truck
    None
    What else can I say other than ignorance is a bliss.
  17. Jul 12, 2023 at 9:22 AM
    #57
    gmtech
    Stock AF
    what seals will start leaking?
  18. Jul 12, 2023 at 10:13 AM
    #58
    zoo truck
    None
    Usually high rpm will affect the longevity of the valve, and main seals. Of course dirt will to. Keeping low rpm is a happy engine.
  19. Jul 12, 2023 at 10:44 AM
    #59
    gmtech
    Stock AF
    how many people have your heard of that have valve seals leaking on their 3.5 or 2.7 tacomas? even ones with 100k + miles.
  20. Jul 12, 2023 at 10:46 AM
    #60
    gmtech
    Stock AF
    so say you had the choice to buy 2 different trucks. one that had been idled for equivalent to 100k miles and one that had been driven from iowa to california over the mountains and back and for its whole life for 100k miles. which one would you choose?
