High RPM Screech 2001 - 3RZ
Discussion in '1st Gen. Tacomas (1995-2004)' started by pheding, Oct 23, 2017.
  1. Oct 23, 2017 at 11:30 AM
    pheding
    pheding [OP] Well-Known Member
    Wisconsin
    2001 Yoda Tankoda 2.7L I4 4x4
    Hello all,
    At high RPMS I get this nasty screeching noise. I'm thinking it's a belt or pulley. Could it be anything else? 2001 3RZ
  2. Oct 23, 2017 at 12:43 PM
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    Definitely belt squeal. Could be just a loose belt but it could also be any of the components attached to the belt. I'd first loosen the belt and check all pulleys (including alternator) for obvious play or signs of failure (scratchy or noisey). If all good, re-tension belt and see what you get.
    Make sure a/c compressor is disengaged, too. Eliminate it from contention.
    Edit: I think I hear some pulley type squeal right as the video ends.
    pheding[OP] likes this.
  3. Oct 23, 2017 at 4:04 PM
    pheding
    Wisconsin
    Thanks man. I’m gonna replace the belts & pulleys This weekend. You know what torque spec that nut is on the pulley?
  4. Oct 23, 2017 at 4:06 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Can also be a bad belt tensioner pulley
  5. Oct 23, 2017 at 6:01 PM
    wamego
    wamego Well-Known Member
    2002 Tacoma 2x4 TRD SR5
    Yes, I've had them all of a sudden scream, and then go away.:thumbsup:
  6. Oct 23, 2017 at 6:43 PM
    pheding
    Wisconsin
    This may be a stupid question but I have to ask. You're talking about the power steering & A/C idler pulleys right?
    US Marine[QUOTED] likes this.
  7. Oct 23, 2017 at 7:10 PM
    Will_Teasley
    Will_Teasley Well-Known Member
    Will
    06 Prerunner
    Had the same exact problem bruh it’s the belt
  8. Oct 24, 2017 at 10:20 AM
    wamego
    It sounds like just a loose or old worn out belt. After you take the belt off, reach in and grab the pulley's by hand and spin them, see if they fell OK. No tight or wobbly spins.
