High rpm upshift
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hajjar, Jan 28, 2018.
  1. Jan 28, 2018 at 2:35 PM
    Hajjar
    Hajjar [OP] Active Member
    Roy
    Tacoma ext
    I have a 2003 tacoma sr5 trd automatic gearbox, which I purchased recently, I noticed that upshifting from first gear happens after 2250 rpm on a flat surface with the lightest throttle. 2nd gear to third changes at 2250 too. Is that normal ? And what to check.
    Thanks all for helping me.
  2. Jan 28, 2018 at 3:24 PM
    New2Tacomas
    New2Tacomas Member
    '01 Dbl cab
  3. Jan 28, 2018 at 10:37 PM
    Hajjar
    Roy
    Tacoma ext
    Hey, yes it has the ect button and its in norm position. Does your double cab have the same shift points?
  4. Jan 28, 2018 at 10:38 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    If you slam your throttle to the floor does it hold the gear longer. This sounds like pretty normal behavior to me so far though.
  5. Jan 28, 2018 at 11:10 PM
    Hajjar
    Roy
    Tacoma ext
    If I floor it yes it does reach 5k rpm, but this is not my issue, Im talking about cruising at low speed with light throttle, 1st to 2nd and 2nd to third doesnt upshift before 2250 rpm. Is that normal?
  6. Jan 28, 2018 at 11:14 PM
    Speedytech7
    I get what you mean, if you had a funky input speed sensor it wouldn't react to full throttle shifts though. So yeah, it sounds pretty normal to me. My land cruiser which has a slightly larger transmission from the same family shifts pretty similar to that.
  7. Jan 28, 2018 at 11:26 PM
    Hajjar
    Roy
    Tacoma ext
    Speedytech, thanks for your helpfull feedback, I checked all my speed sensor, and they all read the same.
    Anybody with a v6 automatic tacoma to share their experience?
  8. Jan 29, 2018 at 3:06 AM
    Hajjar
    Roy
    Tacoma ext
    Guys, the issue is solved, grey wire mod was the problem, it changes the shifting pattern, and cancels overdrive.
  9. Jan 29, 2018 at 12:30 PM
    03 NIGHT TACO
    03 NIGHT TACO Well-Known Member
    Jack
    Eastern Washington
    3.4 5 speed TRD
    Kings/Dakars/ARB
    Huh, never heard of this issue with the grey wire mod before. That's interesting...
