High RPMs at highway speed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jmc1131, Feb 7, 2017.
  1. Feb 8, 2017 at 11:41 AM
    BenTheMan
    BenTheMan Well-Known Member
    Ben
    Portland
    2012 TRD Sport 4x4 AC
    Truck Nutz
    It that the maintenance light or the check engine light? The maintenance light comes on after a set number of miles to remind you to do an oil change. So it could just be a coincidence...
  2. Feb 8, 2017 at 4:35 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Explain what you mean by this. When on the highway, does moving the lever from D to 4 cause it to shift gears? Yes or no.
  3. Feb 8, 2017 at 5:52 PM
    Pigpen
    Dan
    Northwest Montana
    Put 35s on it. Problem solved.
  4. Feb 8, 2017 at 8:21 PM
    Whitetrash
    Whitetrash Well-Known Member
    Jimmy
    San Diego CA and Enon OH
    2008 Prerunner Regular Cab SR5
    Wheeler's AAL, 5100s at 1.75, 265/75r16
    to me it really sounds like O/D is not working, obviously something transmission related. i don't think it would be the rear end unless they put some crazy gears in there when they replaced it, which is probably unlikely.
  5. Feb 8, 2017 at 8:34 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    I say check all of the electrical connections first, ensure they're all secured, then go to an Auto Parts store of your choice (Autozone or O'Reily's) to get the code pulled for the check engine light. When removing the driveshaft from the transmission, a slight amount of transmission fluid comes out. Did they refill it with another type of ATF fluid to your knowledge? Toyota WS fluid is the only type this transmission accepts. It shouldn't make that much of a difference unless they accidentally drained the transmission and put the wrong type of fluid back in.
  6. Feb 8, 2017 at 8:36 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I would think the first thing to do would be to take it to the guys that " fixed" it. They were the last ones to have their hands on it.
    robssol likes this.
  7. Feb 8, 2017 at 9:55 PM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    This will start some fires:
    Actually any Dexron VI ATF would be fine, even Walmart's SuperTech Dexron VI (it's made by Citgo)--though I do not believe I would use it...
  8. Feb 8, 2017 at 10:39 PM
    ZachPrerunner
    Southeast TN
    I'm just hoping the techs where the diff work was performed new about the WS fluid. I realize there are compatible options, but Toyota recommends the WS. I hope they didn't put just any off the shelf ATF in there.
  9. Mar 1, 2017 at 3:40 AM
    jmc1131
    jmc1131 [OP] Member
    Jay
    2010 Tacoma TRD Off Road
    FINALLY got my truck back, was in the shop 18 days, warranty covered everything. The mechanic said the code was P 0776, That is the solenoid right? If it is not too difficult can someone explain how a bad solenoid can ruin a transmission? The warranty company had them drop the pan to find out exactly what was wrong and he said the linkage from 3rd to 4th gear was busted. So now have a new transmission, and triple checked the differential and it is the correct one.
    TacomaMike37 likes this.
  10. Mar 1, 2017 at 6:00 AM
    ItalynStylion
    Steven
    DFW, Tx.
    Wow, good to hear everything worked out for you! Maybe not the result you were expecting but hey, now you have a brand new transmission in a 7 year old truck!
  11. Mar 1, 2017 at 8:42 AM
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    bad solenoid won't let you shift gears causing heat issues and damage internal materials. As poster on page 1 specified ecu puts the vehicle in limp mode to prevent more damage to internals. On my Accord when this happened the drive icon "D" on my display notified me of this with flashing D. Codes read on mine 2 shift solenoids were stuck.
  12. Mar 1, 2017 at 8:59 AM
    eon_blue
    Azusa, CA
    Manual trans swap, problem solved :D
    Glad it got figured out and even better that it was covered under warranty, did you have an aftermarket warranty on your truck or?
