High rpms in park & nuetral..
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2003prerunner, Jul 28, 2010.
  1. Jul 28, 2010 at 6:54 PM
    2003prerunner
    2003prerunner [OP] New Member
    03 prerunner
    30...bfgoodwench a/t
    my 2003 tacoma prerunner 2.7 is running higher rpms in park and nuetral....and is also running about 10-15 mph with out pressing gas pedal...if anyone has some advice let me know thanks.
  2. Jul 28, 2010 at 6:57 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    im having the same problem. im gonna try cleanin my maf. sensor to see if that helps.
  3. Jul 28, 2010 at 7:00 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    try cleaning the maf sensor....and you also may want to try lubing the throttle cable. you may need to see if you can find a "yamaha cable lube tool"....which you may be able to get from a place that services atv's and such.
  4. Jul 28, 2010 at 7:02 PM
    98_Mud_bug
    lucedale Ms.
    yea i was wondering if anybody had done that with their cable, if mine is at a high idle and i bump the throttle it idles down..
  5. Jul 28, 2010 at 7:04 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah, i lube my cables every month or so just to keep them in good shape.
  6. Jul 28, 2010 at 9:24 PM
    pittim
    pittim mittip backwards
    Pink slider.
    your ac on?
