High RPM's while driving ????
Discussion in '1st Gen. Tacomas (1995-2004)' started by PaytonN, Dec 19, 2014.
  1. Dec 19, 2014 at 11:33 AM
    PaytonN
    PaytonN [OP] Well-Known Member
    Payton
    MS
    2009 Prerunner Sport
    Hey guys I didn't know if this was normal or not with a 2.7 4 cylinder,but my truck with stock tires ride normally around 2500 RPM's which seems pretty high to me.
    I drove a Nissan Frontier to Oxford last night it averaged 1500 at the most going 75-80 mph.
    Is it just me or are you guys running near the same. I figured I could get way better gas mileage trying to get it down.
    Any help would be great thanks guys
  2. Dec 19, 2014 at 5:34 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    totally fine and normal
    my v6 stock diff gears and 31s was at that rpm about for 65-70
    now..im at 3000 with current setup.
    Motor will be just fine. RPMs aren't everything, the powerband is the important part. I wouldn't worry about it.
  3. Dec 19, 2014 at 6:36 PM
    PaytonN
    Payton
    MS
    Is there any way to get better gas mileage with that ???
    Plus I'm stepping up to 285's and 17's
  4. Dec 19, 2014 at 6:40 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    if you're changing your tire size, your final gearing will be affected and your rpms will go down. but you'll lose power.
  5. Dec 19, 2014 at 6:50 PM
    PaytonN
    Payton
    MS
    Will I lose major Mpgs ???
  6. Dec 19, 2014 at 10:37 PM
    HenryG
    HenryG Well-Known Member
    Washington State
    What king of mpgs are you getting now?
  7. Dec 20, 2014 at 5:17 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    You won't be able to pull hills on the why as well with bigger tires due to weight and lower overall drive ratio so you will end up down shifting.
    Yes you'll see a small loss in MPGs with bigger tires.
    If you are that worried about mpgs then you're screwed haha bigger tires and armor just mean less and less. If you want good MPGs. Don't do anything to the truck other then staying on top of maintenance.
    It's a truck not a car..never gonna see better then 20 average if you drive like a grandma on her death bed.
  8. Dec 20, 2014 at 6:46 AM
    PaytonN
    Payton
    MS
    Roughly 17 to 18
  9. Dec 20, 2014 at 7:35 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I have a 2.7 with AT, 4wd, stock tires and drive-train. I average around 21 mpg while driving like the grandpa that I am. At 65mph, my rpms are around 2400.
    Its a gutless wonder, but I love it.
  10. Dec 20, 2014 at 8:04 AM
    PaytonN
    Payton
    MS
    Would regearing be necessary with 285's?
  11. Dec 20, 2014 at 9:56 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No. Not required. Helpful but not needed.
