High speed offroad suspension types?
Discussion in 'Off-Roading & Trails' started by Breadstick99, Feb 19, 2022.
  1. Feb 19, 2022 at 10:45 AM
    Breadstick99
    Breadstick99 [OP] New Member
    Lukas
    1999 tacoma, 2wd single cab.
    I have a first gen 2wd tacoma, and I'd like to build it to be high speed off road. I usually slam my trucks but want to do something different from my usual thing, I'm wondering what my options are. I know the ultimate option of long travel, but it's a bit to expensive and I'd like to be able to semi daily the truck. What are my other options, or are there cheaper, lower maintenance options for long travel, even if it performs worse. I can weld and can do fabrication work so that's not a big issue if required.
  2. Feb 19, 2022 at 10:46 AM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Icon 8
  3. Feb 19, 2022 at 10:47 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Mid travel and spring under axle swap is a good start, if that's still too expensive get really good bump stops and lower your expectations on how you define "high speed"... :notsure:
    Lenny Dykstradamus likes this.
  4. Feb 20, 2022 at 6:27 AM
    greymachine
    greymachine @taupetacoma
    SoCal
    19 Quicksand TRDOR 4x4 DCSB
  5. Feb 24, 2022 at 1:23 PM
    Kyle_
    Kyle_ A guy and his expensive hobby
    Kyle
    SoCal (805)
    2021 TRD OFF-ROAD 4X4 DCSB
    @tacoma.kyle on IG
    Baja 1000 but at mach 10.
  6. Mar 18, 2022 at 1:02 PM
    flatironsoverland
    flatironsoverland @FlatironsOverland
    Erie, Colorado
    King suspension is known for their Baja experience, I would look at their line of products. The more bypasses and larger the external res, the better. You'll be creating a lot of heat in that fluid, so more ability to cool it off will make your suspension handle amazing all day.
