High Transmission Fluid Temp
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dmbtacogrl11, Jul 13, 2022.
  1. Jul 13, 2022 at 7:41 AM
    dmbtacogrl11
    dmbtacogrl11 [OP] Member
    Washington
    2017 Tacoma TRD Sport
    Hi everyone, so my truck will randomly get the high transmission fluid temp and will shut down. I recently changed the fuel pump at the dealership and thought it was going to fix the problem. (They had informed me it would) But it didn’t. Any thoughts on this? Or what to do exactly? I am no where near a mechanic and I hate going to them because they take advantage that I don’t know
    Taco4cg likes this.
  2. Jul 13, 2022 at 7:46 AM
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    Why did they think replacing the fuel pump was going to fix high transmission temp? How many miles on it? Has the fluid been changed before? Have you had a look at the trans cooler (If equipped) to make sure its not dirty or damaged and restricting airflow?
    BMH, na8rboy, gudujarlson and 6 others like this.
  3. Jul 13, 2022 at 7:57 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Has your transmission fluid level ever been checked or changed? Low fluid or old fluid can cause friction and higher temps.
    Any modifications to your exhaust pipes? Some Y-Pipe exhaust pipes re-route under the transmission pan.
    Do you have a V6 or 4 cylinder?
    When does your truck shut down (are you towing up steep hills)?
    Lastly, find a new dealer that knows a new fuel pump will not lower transmission fluid temperature.
  4. Jul 13, 2022 at 8:02 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    How was it determined that you are experiencing high transmission fluid temperature? Are you towing? Do you have large tires e.g., 35’s? Is the truck still stock?
    Chew and SR-71A like this.
  5. Jul 13, 2022 at 8:11 AM
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    It says "transmission over temp" on the display when it goes into limp mode and then shuts down as soon as you stop.
    My wife did it to her Rav4 last year. She was driving in S3 (or maybe S4, I can't recall) at highway speeds for about 45 mins, and was probably doing 90+
    10thMTNgrunt likes this.
  6. Jul 13, 2022 at 8:13 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    @dmbtacogrl11 . Try replacing crankshaft position sensor . It’s a known issue with 2016 snd dome 2017 models . It’s easy and cheap
    Superdave1.0 likes this.
  7. Jul 13, 2022 at 8:21 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    How does the CPS give a high trans oil temp warning??
  8. Jul 13, 2022 at 8:32 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Ask the mechanic to check for vacuum leaks and air leaks, especially around the intake. Usually this is easily diagnosed with a smoke machine.
    I have a Volant aftermarket intake and the intake tube kept slipping off a silicone coupler on the trail. Every time it happens, I get the transmission overheat warning on the gauge cluster screen and the engine stalls out. This was very consistent (like 3 times in an hour). There's no direct relation between a vacuum leak and hotter transmission fluid temps, so it's probably just a quirk of the ECM software logic. My problem was eventually solved with a replacement silicone coupler.
    Looking at your post history, it may be related to your other issue: https://www.tacomaworld.com/threads/2017-tacoma-sport-4wd.771073/
  9. Jul 13, 2022 at 8:53 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    OP list modifications please
    ktbell444 likes this.
  10. Jul 13, 2022 at 9:06 AM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Any codes? Could be the transmission atf sensor is getting shorted out. But would need codes and a way to monitor off of that PID to know for certain.
    Taco4cg and SR-71A like this.
  11. Jul 13, 2022 at 9:29 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
  12. Jul 13, 2022 at 9:40 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    how old is your transmission fluid?
  13. Jul 13, 2022 at 10:06 AM
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
    Early models with faulty cps goes to limp mode then high trans temp is lit up.
    Taco4cg, mattleg, ktbell444 and 2 others like this.
  14. Jul 13, 2022 at 10:14 AM
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
    I call it a faulty crankshaft position sensor . OP it’s a cheap part. Nothing to lose except a few dollars . Benefit outweighs the risk
    Taco4cg likes this.
  15. Jul 13, 2022 at 10:19 AM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    It's a 3rd gen Tacoma problem. Try a Google search or search function here. Plenty of threads about it.
    Taco4cg likes this.
  16. Jul 13, 2022 at 10:43 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Being a 17' its probably due for a Trans service anyhow. Id take it to the dealership and have them check the fluid and exchange if necessary.
  17. Jul 13, 2022 at 12:59 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    You'd have to ask a Toyota engineer; but it does.:notsure:
  18. Jul 13, 2022 at 1:33 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I’m a software guy, so I am very familiar with bugs in error handling that lead to misleading error messages. It’s one of my pet peeves that I often try to drill young developers on.
    ktbell444 and splitbolt[QUOTED] like this.
  19. Jul 13, 2022 at 2:06 PM
    splitbolt
    NW Arkansas
    I guess these things happen when you do copy/pasta development.
    SR-71A likes this.
  20. Jul 13, 2022 at 2:09 PM
    gudujarlson
    Minnesota
    I think it’s more due to lack in faith in Murphy’s Law. :)
    splitbolt[QUOTED] likes this.
