High Transmission Temp Warning
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mulligandog, Aug 16, 2019.
  1. Aug 13, 2020 at 4:47 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    OP frequents, apparently just doesn't share updates in his/her own post.
    HondaGM and Junkhead like this.
  2. Aug 13, 2020 at 4:57 PM
    chuymoreno
    chuymoreno Well-Known Member
    El Paso, Texas
    Tacoma SR5
    come on OP @Mulligandog don’t leave us like that!
    I have been reading other post and it seems that all point to the Camshaft position sensor. I will replace it tomorrow I don’t want to be driving down the freeway and having my truck stall
    HondaGM likes this.
  3. Aug 13, 2020 at 5:01 PM
    Gen2Tacoma
    Gen2Tacoma A Question Asked is an Answer Learned!
    North East Atlanta
    Gen2Tacoma that's all have!
  4. Aug 13, 2020 at 5:05 PM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    The answer is in post #2...
    HondaGM and AKGSD like this.
  5. Aug 13, 2020 at 5:09 PM
    Gen2Tacoma
    North East Atlanta
    Never had this warning!
    HondaGM likes this.
  6. Aug 13, 2020 at 5:15 PM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    do you have a third gen? If not you won’t get it either
    HondaGM likes this.
  7. Aug 14, 2020 at 11:29 AM
    TomDom
    TomDom Member
    Tom
    please take it to a dealer and have them submit the problem to corporate so they can realize this needs to be a recall. They couldn't find anything wrong with my truck smh
    HondaGM likes this.
  8. Oct 17, 2021 at 6:02 PM
    kahuna_eht
    kahuna_eht New Member
    Elayne
    2019 Black Tacoma TRD Pro
    Hello everyone!! This just happened to me. It shows the alert of high temperature in the transmission fluid and the truck just turned off. I only have a month with my truck. Is a 19’ TRD Pro. If anyone can say anything. I appreciate it. Thanks a lot!
    HondaGM likes this.
  9. Oct 17, 2021 at 9:20 PM
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
    ECT prevents the torque converter from locking until you reach a higher speed. this would cause higher transmission temps versus not using ECT mode. but the transmission couldn't possibly overheat from driving one mile...are you sure that's all she drove?
    HondaGM likes this.
  10. Jan 5, 2023 at 11:13 AM
    Swhirstein
    Swhirstein New Member
    Scott
    2017 Tacoma TRD PRO
    I have my 2017 Tacoma TRD Pro at the dealer now; was only a half quart low on oil but they don't have an answer as to why it turned on. I was just driving down the road and the light popped on, I live in Iowa where it's cold right now and if it sits over night i can get about 10 miles before it will flash on the dash. My truck doesn't shut off or anything but the chime is really annoying to listen to. So far the tech doesn't have an answer and is reaching out to Toyota for direction. They said they want me to authorize a 1200 to have them drop the pan; they think it's either the wiring harness or possibly the valve body. I told them to hold off until Toyota can give me a more definitive answer as to whats going on. Luckily I have a second vehicle I can drive.
    stftaco and HondaGM like this.
  11. Jan 5, 2023 at 11:15 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Well...i think the OP burned up:bananadead:
  12. Jan 5, 2023 at 6:58 PM
    chuymoreno
    El Paso, Texas
    Tacoma SR5
    Just an update on my experience with this warning. I got the warning Aug 13, 2020.
    Got paranoid and bought the Camshaft position sensor the next day. Long story short, I never got the warning again so the new sensor has been on sitting inside the glove box compartment since then.
  13. Jan 6, 2023 at 2:33 PM
    Swhirstein
    Scott
    2017 Tacoma TRD PRO
    Toyota finally got back to the dealership; sounds like they said it's the transmission temp sensors with wiring harness that is the issue and needs replaced. $1300. Apparently they have 2 other Tacoma's in there with the same problem.
  14. Jan 9, 2023 at 12:07 PM
    Swhirstein
    Scott
    2017 Tacoma TRD PRO
    I didn't pay the 1300 to see if it was the temp sensors because I had a feeling they never drove it again after adding 1/2 a quart of ATF. So I went and got it, no more light. Not sure I'll be dealing with them again. I've read a few different places on the internet and it seems like checking and/or adding fluid should be everyone's first step.
    OnHartung'sRoad likes this.
  15. Jan 9, 2023 at 12:14 PM
    #35
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    if it does happen and it’s not the fluid, maybe the tranny thermistor is giving bad measurements? One could use a IR spot thermometer and check it manually (shoot the tranny with it) next time the light comes on?
