Higher MPG with Premium gas?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by InThePlains, May 15, 2025.
  1. May 15, 2025 at 11:57 AM
    InThePlains
    InThePlains [OP] Well-Known Member
    I've never cared about mpg since I bought the truck, it has ~75k miles now, almost due for oil change. I accidentally filled up with #91 gas over the weekend. 2019 6MT DCSB TRDORP.
    I normally got around 17mpg just daily driving, 18 on a good trip. I just noticed this tank is showing 21.7mpg. Not sure this is true or a fluke. I thought it is a myth.
    Anyway, I will find out tomorrow when I refuel.
    usmc2msu, t0p_d0g and photodoc like this.
  2. May 15, 2025 at 11:58 AM
    eurowner
    eurowner Duke Sky
    Scoty
  3. May 15, 2025 at 12:04 PM
    photodoc
    photodoc Of the paths u take in life make sure a few r dirt
    Northern Kentucky
    '23 TRD PRO 6MT
    So it's possible with these trucks. The compression ratio is really high 11.8:1 which typically requires higher octanes than 87. I have considered looking at the timing on my OBD scanner and comparing the two octanes.
    t0p_d0g likes this.
  4. May 15, 2025 at 12:08 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    No. The energy in BTUs in a gallon of 87 octane is identical to the BTUs in premium higher octane gasoline.
    And those who say they detect a difference in mileage between regular gas and gas with 10 percent ethanol are fooling themselves. It's true that ethanol only has 65 percent of the energy in gasoline so it's only a 45 percent reduction in ten percent of the fuel
    helix66 and BPKlein like this.
  5. May 15, 2025 at 12:09 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    I have been using 93 octane since new and I average 23 to 24 mpg.
    IMO running 87 octane in these high compression engines is what’s causing a lot of members valve issues again that’s my opinion.
    BLtheP and musicisevil like this.
  6. May 15, 2025 at 3:24 PM
    InThePlains
    I'm running 32" tires.
    tarbal255 likes this.
  7. May 15, 2025 at 3:35 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    Not Karen
    The wild west
    2016 SR5 DCSB
    Aesthetically Challenged
    Filler up with Jet A.
    MadKatt, musicisevil and GTGallop like this.
  8. May 15, 2025 at 4:19 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    The opinion has no basis.
    87 since day 1. Had same mpgs. No issues with valves
    Bigmatt503, usmc2msu and jmneill like this.
  9. May 15, 2025 at 4:29 PM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    I bet you would get higher MPGs. But if you do the calculations, the added cost isn't offset by the gains.
    Premium costs ~20% more and will not result in 20% mpg increase.
  10. May 15, 2025 at 4:37 PM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    If ethanol has reduced energy density, there is no way you will see the same BTU's as non-ethanol (91 octane is non-ethanol in most parts of the country).
    musicisevil likes this.
  11. May 15, 2025 at 4:48 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    As I said it’s an opinion I’m entitled to mine same as you are although yours was unsolicited!
  12. May 15, 2025 at 5:13 PM
    InThePlains
    I'm not saying it's worth it, just an observation. In my area the difference is more than 20%. I only get fuel from Sam's and Costco. Today regular is $2.69, Premium is $3.69.
  13. May 15, 2025 at 5:17 PM
    forana
    Kaneohe, Hawaii
    Frick man. Hawaii gets bent over so hard on gas. Current average is $4.59 for regular. Damn
    Willy Lump Lump and musicisevil like this.
  14. May 15, 2025 at 5:24 PM
    JamesR
    JamesR Well-Known Member
    James
    Northeast PA
    2022 Tacoma Sport DCLB, Barcelona Red
    I track my fuel economy pretty regularly. Decided recently to fill a few tanks back to back with ethanol free vs the normal 87 unleaded. Saw absolutely zero difference in fuel economy. This is a stock truck, no mods, original tires and wheel sizes.
    I was a bit bummed because it was $0.80/gallon more expensive!
    Bigmatt503 and musicisevil like this.
  15. May 15, 2025 at 5:40 PM
    BillyE
    BillyE Well-Known Member
    I get better mileage—similar to OP’s observation. I attribute it to the improved drivability at low rpms. I think this is only a thing for manual transmission vehicles
    BC Hunter likes this.
  16. May 15, 2025 at 6:23 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    With modern engines it’s possible to get small gains in efficiency with higher octane fuel, because they can adjust fuel-air mixture, spark advance, etc. based on knock detectors. However, it would likely be hard to measure the difference with any statistical reliability and the extra cost of high octane fuel would likely out do the gains in fuel economy.
    Feel happy your truck accepts cheap fuel unlike a Lexus. Spend the savings on your significant other.
    black bnr32, MadKatt and musicisevil like this.
  17. May 15, 2025 at 6:33 PM
    Vlady
    Issy, WA
    2gr-fks is designed to run on 91 Research Octane Number. Which is the same as US 87
    SandyTaco4x4 and jmneill like this.
  18. May 15, 2025 at 6:38 PM
    fiftysix
    fiftysix Mell-Known Wember
    Midwest
    23 TRD OR, 03 Rust Bucket
    You pay for those MPGs at the pump, not worth it imo
  19. May 15, 2025 at 6:41 PM
    gudujarlson
    Minnesota
    I believe the Lexus versions recommend 93. I don’t know why, but I thought maybe they have higher compression or other mechanical difference that firmware can’t solve easily. It could also just be a marketing decision.
    The Lexus versions are also rated for more output. Not just the fuel? Idk.
  20. May 15, 2025 at 6:41 PM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    Damn! I always cited 91 research on threads like this:anonymous:
