Higher MPG with Premium gas?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by InThePlains, May 15, 2025.
  1. May 16, 2025 at 6:06 AM
    Archimedes
    Archimedes Demanufacturer
    Outside the stupid part of Vermont
    23 DCSB TRD OR MGM
    Full-on degenerate heavy metal banjo music
    May be a fluke... butttttt... depending on where you are at, is it possible the shift from winter to summer gas and temps just happened for you? I have always gotten about an 8 to 10 percent hit on my mgp during winter, and then right back up during summer. It was 40's and 50's for us until like a week or two ago, now it's ~80 the last three days.
    DDP1602 and musicisevil like this.
  2. May 16, 2025 at 6:23 AM
    BC Hunter
    BC Hunter Well-Known Member
    Kootenays, British Columbia
    2022 Black AC OR MT w/all TRD goodies
    TRD: Lift, Exhaust, Air Intake, Skid Plate & "Beadlock" wheels. Batman sticker. 255/85R16 Toyo MTs. Debadged. H9s.
    A 35% reduction (check your math) in the energy content of 10% of the fuel is about 3.5% overall.
    So about the same difference as the change in diameter when going from 265/70/16 to 265/75/16 tires, except in the other direction.
    So, the performance hit from bigger tires is potentially offset by using premium (ethanol free) fuel.
    Is that worth 10-15 bucks per fill-up? Maybe......
  3. May 16, 2025 at 6:38 AM
    Willy Lump Lump
    Willy Lump Lump Well-Known Member
    21’ dcsbmt
    This and that
    Same here, paid 4.59 for gas at Costco the other day. Not premium.
  4. May 16, 2025 at 9:17 AM
    099
    099 Well-Known Member
    2022 White Tacoma Double Cab SR5
    I run 93 in my 2022 Tacoma and my 2011 Camry. It's got to be better because it costs more.
  5. May 16, 2025 at 9:44 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    ^The #1 reason it sells.
    Well, that and creative marketing..
    All the legitimate reasons are secondary.
  6. May 16, 2025 at 9:55 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Basically, you pay more to get more.
  7. May 16, 2025 at 12:12 PM
    SomeGuy_GRM
    SomeGuy_GRM Well-Known Member
    2009 Tacoma SR5 TRD Off Road
    I've known this about my 2nd gen since I bought it. Most Toyotas benefit from higher octane, they just don't need it.
  8. May 16, 2025 at 12:26 PM
    Letstacobit
    Letstacobit Active Member
    Orange County, CA
    2022 Off-Road
    Can confirm better gas milage. Over long sample 2-3 mpg/gallon.
  9. May 16, 2025 at 1:42 PM
    WA7
    WA7 Well-Known Member
    Craig
    PNW
    2021 Trail Edition
    I don't think I get better gas mileage with 93, but I certainly get a lot less (i.e. no) spark knock with it.
    BillyE likes this.
  10. May 16, 2025 at 1:47 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I had my staff run the numbers; it ain't worth it!
    jackn7, Chew and Phlogiston like this.
  11. May 16, 2025 at 1:56 PM
    theluharlifestyle
    theluharlifestyle Well-Known Member
    Parth
    SoCal
    2019 DCSB TRD OR
    If you have a tune built for octane learning, then yes you can get better MPGs.
    I have a KDMax tune and I see a noticeable difference between 87 and 91 in both power and mileage, especially on warm days where the engine will pull timing to avoid knock on 87 octane.
    Stock tune I didn't notice squat when I tried both
    jmneill likes this.
  12. May 16, 2025 at 8:34 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Yea, I fat fingered that. 10 percent ethanol gas would have 96.5 percent of the energy density. Less than 1 mpg at the mileage these trucks get. Mileage increases and decreases are better explained by variability in the quality of pump gas and seasonal or temperature changes.
  13. May 16, 2025 at 10:13 PM
    Chastaco
    Chastaco Well-Known Member
    2020 ORDCSB Cement 4x4 Auto
    Definitely the first time this has been discussed
    Chew likes this.
  14. May 16, 2025 at 10:18 PM
    Chastaco
    Not saying anyone’s right or wrong but gudalsson is usually right. From what I’ve seen
  15. May 17, 2025 at 5:51 AM
    #35
    Jpockets
    Jpockets Well-Known Member
    john
    NY
    2023 Tacoma SR Acess cab 4x4
    On 90 octane non ethanol premium, winter 20mpg, summer 24mpg.In my humble opinion ethanol mixed in with gas is irrelevant....just like cutting cylinder's off in a v8 it doesnt do a thing for the good in any engine.
  16. May 17, 2025 at 9:13 AM
    #36
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    Despite having a solid understanding of 4-stroke engines, compression and octane; I went ahead and ran 3 back to back tanks of 93 in my truck and noted no difference other than costing about $20 more per fill-up. I suppose tried it in order to definitively prove to myself that adding octane to a platform that doesn't require it serves no benefit.
    I use an app to log maintenance and it also tracks each fill-up which calculates the MPG.
  17. May 17, 2025 at 9:34 AM
    #37
    InThePlains
    InThePlains [OP] Well-Known Member
    I didn't fill up the tank yesterday, wife has an eye exam requires dilation, I drove her to work. I'm gonna fill her Lexus ES350 had the same gas from the same station see if there's any difference on the MPG between 87 and 91. Her car always gets 87, 26-27mpg.
  18. May 17, 2025 at 6:54 PM
    #38
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Kumho AT52 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 replacement head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    87 adequate for acceptable MPGs.
  19. May 17, 2025 at 7:06 PM
    #39
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    I’m not concerned about mpg I’m more apprehensive about what 87 octane is doing to the valves. Using low-quality fuel, especially fuel with a low octane rating for a 2gr-fks high-compression engine 11.8:1, can contribute to pre-ignition potentially leading to burnt valves.
    SomeGuy_GRM likes this.
  20. May 17, 2025 at 7:09 PM
    #40
    SomeGuy_GRM
    Exactly. I use 91 for the performance increase. If it gets me better mpg, that's just a bonus.
    t0p_d0g[QUOTED] likes this.
