Higher Output Alternator Possibilities
Discussion in '1st Gen. Tacomas (1995-2004)' started by Blue92, Sep 12, 2017.
  1. Sep 13, 2017 at 10:40 PM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    Thanks for the correction Monte, had that backwards.
    Blackdawg[QUOTED] and Dalandser like this.
  2. Sep 13, 2017 at 10:43 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I had a physics teacher that talked about voltage like potential energy from a height about the earth - the larger the voltage the higher is something off of the ground so it has more potential energy waiting to be turned into kinetic energy while falling back to earth. Current could be like flow in a river usually measured by cubic feet per second (cfs) that passes through a given plane at any moment.
    So you could have a water drop fall from low earth orbit and it wouldn't hurt you when it landed on your head. I guess that would be a low current, high voltage scenario. Meanwhile a river dumping a 1000 cfs onto your head from 10 feet up might not feel too good. I guess that would be low voltage, high current.
  3. Sep 14, 2017 at 9:53 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    A couple things with the CS144.
    Go with a reman GM unit not a "new" aftermarket. The new Chinese knock offs have a bad rep for using low quality parts, both electrical and bearings. You have a "better" chance with a domestic rebuild.
    For those that just can't let anything go unmodified, a 17mm bore, 4 groove 57mm fully machined pulley can be had.
    If you are chronically affected, the adapter plug can be messed with. The Toyota end is fine but the wire size on the GM end is a little small for the holes in the rubber seal. Pop the pins and apply one layer of heat shrink and plug the empty 4th hole. Keep that water at bay.
    Dalandser and Blackdawg like this.
  4. Sep 18, 2017 at 8:14 AM
    Toyota4x46921
    Toyota4x46921 Well-Known Member
    Michael
    Warner Robins, GA
    is this a direct bolt on or do you have to add washers and such? If so where?
  5. Sep 18, 2017 at 9:25 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Check post 6.
  6. Sep 18, 2017 at 9:26 AM
    Toyota4x46921
    Michael
    Warner Robins, GA
    Thanks....I am blind....lol
    Dalandser[QUOTED] likes this.
