Higher than typical, floor jacks??????
Discussion in 'Garage / Workshop' started by Airun, Sep 28, 2010.
  1. Sep 28, 2010 at 11:54 AM
    Airun
    Airun [OP] Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    Didn't quite know where to post this topic yall, but here goes. I like to rotate my tires frequently, every 2or3k miles. Anybody know of a floor jack that can lift our Tacos (mine 2" lift) from midpoint of frame to get both front and rear tires off the ground for quick rotation. Obviously taking care to avoid ever having a body part anywhere near the underside of the truck when jacked. A stack of screwed together 2x12s works ok but cumbersome.
  2. Sep 28, 2010 at 12:00 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I wouldn't recommend lifting the truck from the center. I would get some big jack stands and one in the front and one in the back. If your jack fails with both wheels off your going to have a lot of repairs to do.
  3. Sep 28, 2010 at 12:08 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Do you have some short jack stands?
    Lift the rear of the truck underneath the rear diff. Place jackstands (smaller sized) under each ubolt plate at each end of the axle - thus rendering the entire rear end off the ground. Then - take your hydraulic jack and lift the front (behind tire on the frame - see owners manual) one side at a time. Rotate and do the same to the other side.
    Don't forget to use a wheel chock/s on each front wheel that is in contact with the pavement.
  4. Sep 28, 2010 at 12:11 PM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    with a 2" lift pretty much any jack should work just fine
  5. Sep 28, 2010 at 4:23 PM
    Airun
    Aaron
    Show Me State
    Yeah, thats how I've been doing it for years. I guess it would probably be ignorant to try this technique on a 5000lb. auto, but sure works great for a 3000 pound car when you only need it up for 10 minutes to swap tires and check brakes. NEVERMIND:D. Thanks for talking some sense into me before I hurt myself, or worse, my Taco:eek:
  6. Feb 12, 2011 at 4:31 PM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    Even stock my 20" jack has a hard time getting wheels off the ground (front). The rear is a piece of cake as mentioned. Now i have a 2" lift and I have to use wood blocks but dont know if there is something better? Some sort of rubber chock or something to get higher lift? I dont have room for a larger jack (single car garage and I am packed for tools.
  7. Feb 13, 2011 at 6:20 AM
    Airun
    Aaron
    Show Me State
    yeah, I've looked at 23" jacks but$$$$$$$$$$. eventually I'll spring for a big stable one
  8. Feb 13, 2011 at 11:30 PM
    pittim
    pittim mittip backwards
    Pink slider.
    if you jack up using the LCAs the suspension has zero down travel...
  9. Feb 15, 2011 at 8:21 AM
    Airun
    Aaron
    Show Me State
    yeah we're talking about the highly unsafe and not recommended procedure of jacking up one side for tire rotation by using the balance point along the frame rail in order to get both tires off ground
  10. Mar 14, 2011 at 5:41 AM
    teamfast
    Winnipeg, Manitoba
    '10 DCLB
    Suggestions for a safe cheater block? I need about 4-6 inches to make it work on the framerail
  11. Mar 15, 2011 at 6:16 AM
    Airun
    Aaron
    Show Me State
    I use a stack of 2x12s screwed together. 3 of em about 3 ft. in length. its pretty stable, but wouldnt' call it safe by any means.
  12. Mar 15, 2011 at 8:41 AM
    teamfast
    Winnipeg, Manitoba
    '10 DCLB
    Yeah just getting the jack under the LCA is a PITA.
  13. Mar 25, 2012 at 11:40 AM
    Pit Snipe 1997
    Pit Snipe 1997 Well-Known Member
    Scott
    Maryland
    TRD off road
    Plasti coated grill and rear bumper along with all badges. Rigid Industrys D2 Driving lights. Money is tight so more to come soon hopefully.
    Craftsman makes one for trucks and suvs. the stroke is quicker and you get more lift faster.
  14. Jun 16, 2012 at 10:59 AM
    Pit Snipe 1997
    Scott
    Maryland
    TRD off road
    Craftsman sells one for trucks and SUVs. Its stroke is quicker and i have never had to add blocks.
  15. Jun 16, 2012 at 1:53 PM
    Airun
    Aaron
    Show Me State
    Are you lifted by any chance Scott?
