Highest mileage first gen
Discussion in '1st Gen. Tacomas (1995-2004)' started by Olysouthpaw24, Jan 7, 2012.
  1. Dec 10, 2013 at 11:24 AM
    #61
    RyanC
    RyanC Well-Known Member
    Puyallup WA
    95 Tacoma 4x4
    Lifted, 33/1250/15's, canopy.
    Some of you guys make my 95 with 230K seem like a new truck. Its all original though, that's a start I suppose
  2. Dec 10, 2013 at 12:46 PM
    #62
    Changeling
    Changeling Well-Known Member
    Maryland
    2001 Tacoma TRD SRD V6 X-Cab Limited Edition
    2001 4x4 Tacoma Limited xcab. I bought it a few weeks ago with 87,xxx, now has 88,xxx.
    Before this, 1999 4x4 Tacoma xcab 4x4, 180,000 then frame rust did it in with very little warning, everything was maintained 100% plus!
    2002Tacoma4x4 likes this.
  3. Dec 10, 2013 at 12:49 PM
    #63
    Pdugan6
    Pdugan6 Well-Known Member
    Patrick
    Sunnyvale California
    3 link solid axle 2011 Tacoma 4x4
    My buddies 2001 access cab has 360,000 on it and is still going. He just bought a 2014 tundra to replace it as DD
  4. Dec 13, 2013 at 9:59 PM
    #64
    KrzyKjun512
    KrzyKjun512 Well-Known Member
    Chad
    2000 TRD, Original Rust-Free
    2000 3.4 w/ 222k. And the best thing about it (besides being one of the last greatest trucks made)....No Monthly payment :cheers:
  5. Dec 14, 2013 at 10:06 AM
    #65
    vtrguy
    vtrguy Well-Known Member
    Jarrod
    Chico
    '01 Taco TRD xCab SR5
    Deckplate, Full OME kit, Snugtop Camper, Camry ignition ring, TRD Catback
    01 3.4 TRD 4x4 5-spd with 229,831.
    OE clutch and tranny.
    Needs a new clutch though (mostly from TOB noise) and input shaft bearing... and timing belt... and carrier bearing... and tires... and the locker rebuilt... and maybe a brake booster, but I actually like the stiffer brakes :rolleyes:
    But everything else is cherry :p
  6. Dec 15, 2013 at 6:14 AM
    #66
    cdcoker
    cdcoker New Member
    Clabe
    Knoxville, TN
    01 SR5
    none yet
    01 2.7 4x4 300,576
    Runs like a dream..the guy that had it before me took it to the dealer for everything..
  7. Dec 18, 2013 at 11:25 AM
    #67
    SanPedrotaco
    SanPedrotaco New Member
    Rob
    So Cal
    03 prerunner SR5
    300,000+ on my 2003 sr5 2wd, crew-cab. Bought it with 5000 on the odo. Changed fluids (regularly) brake pads, couple of batteries and little else aside from standard maintenance. Original timing belt tho....I am way overdue for this btw. Love my taco
  8. Dec 21, 2013 at 10:47 PM
    #68
    ThatTShirtGuy
    ThatTShirtGuy New Member
    Gardnerville, NV
    98 Tacoma 3rzfe 498k mi!
    Sooo close to half a million! 98 2.7 ext cab 4wd. Literally 98% original. Got its first clutch at 480k. Would trust this truck to drive across the country right now.
    9A32402D-0098-44A2-AA08-3DBCCBF30366_zps_2a7f177017c87eaa152d30e5ed8cbc9189944db0.jpg
  9. Dec 21, 2013 at 11:37 PM
    #69
    muddedtaco
    muddedtaco Well-Known Member
    Wesley
    South Mississippi
    96 Tacoma 4x4 2.7
    Rattle caned black, Mossy oak door panels, shifter shroud, and radio cluster surround
    I have a 3rz 213xxx on mine, needs to be rebuilt but, the person I bought it from dogged the hell out of it had sand in the air box and water in the oil. No regular maintenance done at all. Still runs burns no oil just no compression, show me another manufacture that would still run right. Toyota all the way!
  10. Dec 22, 2013 at 1:17 AM
    #70
    Loggerhead
    Loggerhead Well-Known Member
    Seán
    Alaska
    2002 SR5 TRD 5spd 3.4 Xtra Cab
    Wow! :eek: Awesome job! I hope that my truck and I can make the same claim some day :D
  11. Jan 9, 2014 at 9:25 AM
    #71
    jdenny
    jdenny New Member
    Muldrow, Oklahoma
    98 Tacoma 4x4
    1998 Tacoma Ext Cab 4x4 2.7 liter, 421,000 miles. Rings, bearings, tie rods, springs, shocks, steering rack, carrier bearing and it's still runs great with plenty of power and uses about 1 quart between changes. I change my oil every 5000 miles and run Mobile Delo 5w-30.
  12. Jan 9, 2014 at 3:35 PM
    #72
    Icemansurf
    Icemansurf Member
    02 TRD
    2002 4WD V6 manual, did the clutch last year, and other than that just some spark plug wires and Idle Speed Control as far as "major" work. Bought it with 39k miles seven years ago and today just rolled over 208k. Weeeeeeeeee
  13. Jan 9, 2014 at 7:34 PM
    #73
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    01 with 231,000. New suspension, ome 880s, wheelers 5 leaf springs, rc shocks and bushings etc, o2 sensors front and rear, minor fluid seepage. Abused by prior owner. Despite all that, no oil burning and she is a blast to drive. Frame was replaced in fall of 2012, a year after the suspension work was done. She's for sale since I have another. Tough decision on which one to keep though.....149,000 on the 03.
  14. Jan 10, 2014 at 3:45 AM
    #74
    NJBill
    NJBill Member
    Bill
    Jacksonville, Florida
    97 Tacoma
    97 daily driver with 209k.... They will probably bury me in it.
  15. Jan 10, 2014 at 1:56 PM
    #75
    adamsson00
    adamsson00 Active Member
    Jeff
    Cape Breton, NS
    2009 Silver Tacoma TRD
    I just bought my 02 this past july, as far as I know the drivetrain is original, 198,000 miles and 1 rebuilt title (front end collision). I put metal in the frame, and a rad in it, its now got 210,000 miles and I flipped it on its roof twice... still runs like a top
  16. Jan 10, 2014 at 2:13 PM
    #76
    jamco20
    jamco20 Well-Known Member
    James
    Socal
    Bilstein 5100's up front
    I have an 03 V6 prerunner with about 175,000 and nothing has been wrong with it! I'm kind of curious though as to if i should change my O2 sensors, they have never been changed. I'm not getting a CEL but would new ones make the truck run better?
  17. Jan 10, 2014 at 3:00 PM
    #77
    Jimothy
    Jimothy Lurker
    Jim
    Washington
    01 PreRunner TRD
    Bed full of Dive gear.
    I just hit 180k this week, changed out the AFR sensor last October, made no difference performance wise, but did put an end to the constant P1135 code.
  18. Jan 10, 2014 at 7:06 PM
    #78
    jamco20
    James
    Socal
    See I don't have any codes...so I guess I'll just wait until i get one? I try and take the best care of my truck i possibly can...
  19. Jan 20, 2014 at 4:50 PM
    #79
    Motoperpetuoso
    Motoperpetuoso Moto Perpetuo
    Texas
    2001 Prerunner sr5 Xtra-cab red
    Bull Guard, Bed Lights, LED Dome light, Reciever Hitch, aftermarket stereo/speakers, tint, chrome, steps, bigger tires
    Bought my 2001 prerunner xtracab for 6500 about 6 months ago from the original owner with 160k miles. I know these trucks and I knew I was buying it as just a baby!
  20. Feb 9, 2014 at 6:45 AM
    #80
    sandmountainslim
    sandmountainslim Member
    Alabama
    pickup
    2004 2wd Tacoma. 443,335 miles!
