Highest mileage first gen
Discussion in '1st Gen. Tacomas (1995-2004)' started by Olysouthpaw24, Jan 7, 2012.
  1. Nov 12, 2016 at 7:47 AM
    #161
    1997tacomav6
    Denver
    My situation was either fix head gaskets at 485,000 or replace the motor, I decided with a motor
    I found in a rolled truck that had 100,000 miles on it and I could hear it running and verified the miles
    for 1500.00, this was my best decision, come to find out the heads were cracked and would have cost a lot more the other way and would have still had 480,000 miles on the old engine. Came with injectors,
    alternator wiring harness power steering all the extras that I just swapped over
  2. Nov 12, 2016 at 7:50 AM
    #162
    1997tacomav6
    Denver
    Thanks, it's a work in progress at 515,000 now,
  3. Nov 12, 2016 at 7:50 AM
    #163
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    Turned 198k on my 2.7L 4 door
    Love it
    Hope it lasts till 300k
    Not a mark on her
    Immaculate inside and out
  4. Nov 12, 2016 at 8:26 AM
    #164
    Tacotruck7
    Tacotruck7 Well-Known Member
    SoCal
    04 Prerunner Dbl Cab 2.7L
    I got my truck with 185k on it. Really hoping it will last till at least 300k. What's the secret? Religious oil changes every 5k?
    PROseur likes this.
  5. Nov 17, 2016 at 1:04 PM
    #165
    LGG
    LGG Active Member
    1998 Tacoma DX 2wd
    Original except radio
  6. Nov 17, 2016 at 1:08 PM
    #166
    LGG
    LGG Active Member
    1998 Tacoma DX 2wd
    Yeah i probably will do just that ..find another motor n swap. I really want to then rebuild the original motor on a stand in the garage . ..did v8s for years.Put the original motor n new clutch n go to 1 million . ..replace ballballjoints .at 750k. .frame...me.
  7. Nov 17, 2016 at 1:09 PM
    #167
    LGG
    LGG Active Member
    1998 Tacoma DX 2wd
  8. Nov 17, 2016 at 1:15 PM
    #168
    LGG
    LGG Active Member
    1998 Tacoma DX 2wd
    Im at 417k mi...I was told by a service dept wizard oil every 5k n factory filter and the timing chain will last beyond 320k. machinist buddy hammered on me about radiator flushes...aluminum head water passages corrode thru. ...check this site! they clued me into balljoint failures ! plugs wires @ 300k n it freshened up the power . dont drop crud into cylinders...vertical plugs...@270k killed a z motor nissan pickup:(
    Tacotruck7 likes this.
  9. Nov 17, 2016 at 1:17 PM
    #169
    99SuperTaco4x4
    99SuperTaco4x4 Well-Known Member
    1999 3.4L V6 Tacoma, 4x4, TRD Supercharger
    are you trying to raise your post count? lol You are quoting people with no response multiple times. It's probably just an accident. Technical tip: just click the quote (or multi-quote if you are doing multiple people/posts) button, and then type your response below the quoted text, then click post.:thumbsup:
  10. Nov 17, 2016 at 1:22 PM
    #170
    LGG
    LGG Active Member
    1998 Tacoma DX 2wd
    Oppps
    99SuperTaco4x4 likes this.
  11. Nov 18, 2016 at 2:18 PM
    #171
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    My engine is just getting broke in! Still runs perfect with plenty of power! No major issues so far.
    2002Tacoma4x4 and PROseur like this.
  12. Nov 18, 2016 at 2:49 PM
    #172
    PROseur
    Pussy
    If my 4 cyl goes 50k more miles and reaches 250k, I will be very happy. Running like a top now.
  13. Nov 21, 2016 at 10:31 AM
    #173
    jgill21
    jgill21 Not Technically Stock Anymore
    Jake
    Nashville
    98 2.7 TRD PreRunner
    Just breaking mine in, 250k. Runs like it's brand new!
    GQ7227 and Sicyota04 like this.
  14. Dec 21, 2016 at 5:03 PM
    #174
    westly7
    westly7 Well-Known Member
    Westley
    01 tacoma 2.7 auto 2wd
    292900 on my 01 pre runner 2.7
  15. Dec 21, 2016 at 6:06 PM
    #175
    specialized7
    specialized7 Well-Known Member
    ,Saskatoon, Canada
    05 v6 4x4
    440 on mine and have done nothing major to the motor or trans.
    also this truck has the factory wheel bearings in it and factory starter!!!
  16. Dec 21, 2016 at 6:08 PM
    #176
    99SuperTaco4x4
    How long have you had the supercharger on that same engine?
  17. Dec 21, 2016 at 6:50 PM
    #177
    DTTRD
    DTTRD Well-Known Member
    Don
    San Diego, CA
    DCLB
    Icon Stage 4 MaxTrac Spindles 285/70/17 BFG AT
    I have 85k on a 1999. I have a long way to go.
  18. Dec 26, 2016 at 6:28 AM
    #178
    specialized7
    ,Saskatoon, Canada
    05 v6 4x4
    it was only supercharged for 20 k
    I kept getting a lean code so I removed it.
  19. Dec 26, 2016 at 9:37 AM
    #179
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    No a lot of miles still thought I would share
    GQ7227 and 2002Tacoma4x4 like this.
  20. May 30, 2020 at 10:37 AM
    #180
    rtwbound
    rtwbound Well-Known Member
    bump
    GQ7227 likes this.
